Whats going on here?
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
This morning while driving to work and then back home I kept getting an error message on my dashboard/speedo read out that said "Cruise Control Not Available" Then a little later the Adaptive Cruise Control would light up and the readout would read "driver interference" then jump back to "cruise control not available" Whats going on? FYI, I have a 2004 XJR with lower mesh on my car that's been on for over a year without an issue.
Good luck!
albert328gts (12-23-2011)
albert328gts (12-24-2011)
This could ultimately require the Jaguar diagnostic equipment to really see what the system detects. The system is complicated and seemingly unconnected things can mess with you. A good example I have run into is a guy changing his wheel size and not having the car reconfigured to that size. The car [wheel] speed says one thing, and the ACC constantly calculates the speed of things coming at it. Well, if it always sees things approaching at something DIFFERENT than road speed, it says, "this can't be right, I must not be able to see, my sensor must be blocked". Bingo, a "Sensor Blocked" message.
Good luck!
