Wheel Fit Details?
Old 01-23-2015, 04:39 PM
Fraser Mitchell's Avatar
Received 2,450 Likes on 1,948 Posts
Well done. Happy Motoring !! Did they come with the tyres too, as they don't look too worn ?
Old 01-23-2015, 05:27 PM
ProlixArgon's Avatar
No, these came off a X351, so the tires are the wrong sizes.
I did get the TPMS sensors too, but the newer sensors are probably different? If I remember correctly somewhere along the way they switch from a 315mhz to a 433. More forum digging will probably answer that one.
Old 01-23-2015, 05:54 PM
Received 4,454 Likes on 2,426 Posts
Front tyres on the X351 should be the same as the X350...if it's a staggered set then the rears would be wider, but *should* just fit. What's the size & offset, and the tyre sizes?
Old 01-27-2015, 10:15 AM
The tires were 245/40-20 in the front and 275/35-20 in the back. Slightly thinner in the front, and slightly wider in the back. These will function until I can find the "right" wheels and can be re-sold when I'm done for, hopefully, about what I have in them.
The offset is supposed to be the same. They came of a 2011 XJL.
Old 03-22-2015, 10:57 AM
It's been a while, but I thought I would share a picture with the wheels installed. I don't like them as much as the original wheels, but they are pretty nice.
On a separate note: do the exhaust tips look stock? There is some cursive signature that I can't make out on the top of the outlets and I wondered if perhaps they were changed at some point. Everything looks stock to me, but I've not seen stock exhausts stamped with anything except factory badges.
hawaiianjag (01-11-2018)
Old 03-22-2015, 03:57 PM
No those are not the factory Portfolio exhausts. Which is a pity because the Portfolio had some special exhaust finishers that are no longer available to buy from Jaguar...
Old 03-22-2015, 04:06 PM
SimonXJ's Avatar
Good news if the Mataiva wheels fit though, I rather like them..
  #28
Old 03-22-2015, 07:55 PM
The wheels do fit fine, but I have only driven it around the lot as other parts of the repair aren't done yet.
I figured out the exhaust is by Mina Gallery, which isn't extraordinary? I do like the way it sounds, but I don't a stock exhaust to compare with. It's got a deep rumble without being load, and is not very audible in the cabin.
SimonXJ (03-24-2015)
H20boy
07-23-2021 09:39 PM
dsnyder586
04-04-2019 02:38 PM
steve_k_xk
Non-Jaguar Vehicles
05-17-2016 05:29 AM
08Z06
10-24-2015 05:46 PM
smith356
10-07-2015 06:41 PM
Quick Reply: Wheel Fit Details?
