wheel nut torque ?
Old 02-20-2013 | 01:39 PM
blindboy's Avatar
Default wheel nut torque ?
anyone know lug nut torque for 19" xjl wheels on new"Brake Performance " drilled & slotted rotors ?? thanks..
Old 02-20-2013 | 03:20 PM
bobert52's Avatar
Factory spec on that vehicle is 92 flbs
if these are after market rotors you should check your supplier however i dont know why they would be different
blindboy (02-21-2013)
Old 12-06-2021 | 10:23 PM
Xeno's Avatar
Compiled by Danny Sparky of Sparky Express, from https://www.sparkyexpress.ca/blogs/a...t-torque-chart (the original, at that link, is nicely formatted as a table):
Jaguar Lug Nut Torque Specs, All Models
Make Model Trim Year Range Torque
F-PACE - 18 INCH 18"BASE / 20D 2017 - 2018 105 ft-lbs
F-PACE 20D 19"BASE / PRESTIGE 2017 - 2018 105 ft-lbs
F-PACE 35T 20"BASE / PREMIUM 2017 - 2018 105 ft-lbs
F-PACE - 19 INCH 19"BASE / 20D 2017 - 2018 195 ft-lbs
F-TYPE 19"BASE / S 2014 - 2018 95 ft-lbs
S-TYPE - ALL 16-INCH / ALL 2000 - 2008 95 ft-lbs
XE 17"BASE / 20D 2018 - 2018 100 ft-lbs
XF 18"BASE / 4.2 LUXURY 2009 - 2016 95 ft-lbs
XFR 20"BASE / SUPERCHARG 2010 - 2015 95 ft-lbs
XFR-S 20"BASE / SEDAN 2014 - 2015 95 ft-lbs
XJ 20"OPT / BASE 2011 - 2016 100 ft-lbs
XJ ALL / VANDENPLAS 1996 - 2003 75 ft-lbs
XJ SEDAN / VANDENPLAS 2004 - 2009 90 ft-lbs
XJ - ALL ALL / ALL 1994 - 2003 75 ft-lbs
XJ8 BASE / SEDAN 2004 - 2007 90 ft-lbs
XJ8L 18-INCH / SEDAN 2006 - 2007 90 ft-lbs
XJL 20"OPT / BASE 2011 - 2016 100 ft-lbs
XJLR 20"OPT / ALL 2011 - 2011 100 ft-lbs
XJR 20"OPT / ALL 2011 - 2016 100 ft-lbs
XJR ALL / S 1993 - 2003 75 ft-lbs
XJR 19-INCH / SEDAN 2004 - 2009 90 ft-lbs
XJS ALL / ALL 1982 - 1996 75 ft-lbs
XK 19-INCH / CPE/CONV 2007 - 2015 75 ft-lbs
XK 18-INCH / CPE/CONV 2007 - 2008 90 ft-lbs
XK8 CPE/CONV / BASE 1997 - 2006 75 ft-lbs
XKR CPE/CONV / ALL 1999 - 2015 75 ft-lbs
XKR 19-INCH / CPE/CONV 2007 - 2015 90 ft-lbs
XKR-S 20"BASE / CPE/CONV 2012 - 2015 75 ft-lbs
X-TYPE SEDAN / 2.5 2002 - 2008 75 ft-lbs
Atheos
04-28-2021 10:30 AM
TH3FRB
08-21-2019 09:14 PM
Jag7
12-18-2018 02:51 AM
slojotaa
F-Pace (X761) / C-X17
07-24-2016 09:05 AM
slojotaa
06-17-2016 10:13 AM
Quick Reply: wheel nut torque ?
