Wheel paint
I have the same wheels and my suggestion would be to take them all to a re-furbishing shop and get them straightened and powder coated. A patch job is never going to look any better that the scrapes your trying to cover. Also 3 out of 5 of mine were bent and I bet some of yours are too.
Good Luck
Jeff
Good Luck
Jeff
The following 2 users liked this post by roviw:
Canuck pump engineer (07-25-2021),
meirion1 (07-24-2021)
Since my old Lexus LS had strong wheels and powder coating , I was concerned about how to repair my XJR wheels when I bought it since they were curbed pretty badly.
I discovered that the XJR wheels were pretty soft (bend easily) and appeared to have been sprayed with normal paint . So no harm in sanding and wet painting .
Maybe I should have taken them to a shop to have them straightened and powder coated. But since they looked pretty straight (with tires off), I used spot putty on the curb rash , sanded and spray bombed them with a finish coat of spray can clear. Cheap, and they look great!
A bit time consuming , plus they are not a durable as powder coating of course .
edit. Oh!. Since I sprayed all the wheels, matching the silver was not a concern. So sorry, I don't have a direct match color.
