wheels too tight - won't come off
Sad day for my car. I got a new set of tires, went to a tire shop to install them. The folks found that the lug nuts are way too tight and won't come off. One broke, right at the start of the stud thread.
The proposed solution was to drill the studs (5 per wheel) then replace them. However it looks like on the front wheels the studs don't come as separate part for some strange reason, one needs to order the whole hub (c2c019585). parts.com has it for $256.75.
Any suggestions would be appreciated.
This is a good case for finding a couple cans of Kano Aerokroil by Kano Labs (go to their web site). Soak the lugs as well as you can with this over night. Use both cans and get it good. There has never been anything so corroded that I could not get it loose with this stuff andI restore classic motorcycles. This oil will soak rightthrough steel I think.There is no penetrant in the world close to this stuff, just a happy user. You can bet those lugs will come off safely unless they are cross threaded.
The lug nutsdo have stainless sheet metalcaps but the part that is hanging up is a large CAD coated metal washer against the aluminum alloy wheelpressed down bya resilient pad of some epdm-like material, with a normal alloy screw thread inside of it all holding to the hub stud. All this alloy and cad generates enough stray current to light up Toledo, making it a sure thing that a rough surface will develop to cause you grief.The Aerokroil will find its way into the screw thread and under the washer, but it will take a little quantity and a little time. It will dissolve the corrossion in there. I coat low grade stainless exhaust systems (XJ6)with the stuff to keep it from corroding as well as high carbon tools and so on.
Guest
Posts: n/a
I was looking at mine the other day and noticed that one of the chrome covers was missing.
I have the standard XJ alloy rims, I think they are called Dymamic (thinking about replacing them with chrome 18" Penta Sport - Soft 5 Spoke, or maybe just thesame Dynamics in chrome)
I have not tried taking the wheels off yet, but in looking at it, I assumed that the chrome covers were to be removed before going after the lug nuts (especially since one has dissappeared).
Is this not the case?
I was thinking about replacing the lugs/covers combowith actual chrome lugs.
Is that do-able?
Is that do-able?
Small update. I managed to remove one of the broken nuts. Pictures here http://picasaweb.google.com/veffremo...ey=w7z50ncbAHw. Took about 5 hours.
Two more came off it a little persuasion from the air impact wrench.
The dummy who last worked the tires put one of the rear ones backwards.
