Wheels for XJR vs XJ8
04-08 had same bolt pattern: 5x108
Wheels on XJR were 19 or 20 inch most of the time.... All had a +48 offset. I have XKR wheels from a 2010 on my XJ8... They are bad ***!
It is not the wheels you have to worry about.... XJR, XKR, and S type R all had Brembo brakes... They are large, and can strike some 18 inch wheels... You will need to check for clearance before mounting em... If they clear, you will be fine....
Cheers!
Cheers!
hunter34
19
09-15-2022 12:09 AM
