When to change oil?
While I'm new to the Jaguar forum, I've been around, elsewhere.
Both of our vehices are on 10K mile changes. The Mercedes holds 8 quarts and seems to love Delvac 15-w40 diesel oil (odd, but go figure), and the Lexus gets Mobil 1
I've been doing 10K mile changes for, wow, since the early-90's, on Mobil 1, and have never, ever had an oil-related problem.
3K mile changes were fine, when oil was still pretty low-tech pre-mid-80's, but it's come a long, long way.
Even on the Honda ST1100 sport touring motorcycle I used to have, with unit lubrication of the engine/transmission (shared oil), I changed it at 5K miles. Knew some who did 10K, but they'd do said 10K miles in a week. Seriouslly.
www.ironbutt.com
www.ironbutt.com
Even back in 1980, Jaguar were on 7500 mile oil changes, but clearly, if one does lots of short journeys tootling around town, shorter intervals are beneficial. Oil is cheap, engines are expensive, sort of thing, but 3000 Kms !! Now that is really way, way, over the top on cautiousness. You must be changing oil every 2-3 months !
Pauley, Pauley, Pauley..
Did you buy the car or what, I understand your excitement but come on man, get a fkn grip, buy the car, drive the damned thing, love it, it is a Jaguar, it has a soul.
Now , if and when you buy it, and if any other problems pop up, ask on..but please, please,till then,and only then put all your f k n Q,s in one post.
PaulB (03-05-2011)
Typically diesels also hold significantly more oil than do gasoline engines as well.
I have a vehicle equipped with a Cummins ISB turbo-diesel. Factory specs state change it every 12 months or 15K miles (24K km). That 5.9L engine does have a 4 gallon (15L) oil capacity, however.
Turbochargers are rough on oil...lotsa extra heat to remove from the turbo's bearings due to it being driven by scorching exhaust gas.
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
aholbro1
08-05-2021 05:02 AM
