Where is the computer?
Old 03-14-2015 | 05:34 PM
XxSlowpokexX's Avatar
Default Where is the computer?
Silly question but I really have no idea where it is. AND is it difficult to pull
Thanks!
Old 03-14-2015 | 09:36 PM
dsetter's Avatar
Which computer, there are several, engine, transmission, body, entertainment, climate, etc.
Old 03-14-2015 | 09:51 PM
Cambo's Avatar
If you mean the ECU it's under the glovebox, remove the carpet trim under the glovebox and you'll see it. It's held in with some security Torx bits, from memory they are 5-point instead of the usual 6-point.
XxSlowpokexX (03-17-2015)
Old 03-15-2015 | 12:36 AM
Don B's Avatar
Also, the ECM connector is accessed from the engine bay, under the cabin microfilter housing, which must be removed. The manual states that you must remove the windshield wipers and windshield cowl, but I was able to get the microfilter housing out by just removing the fasteners on the right end of the cowl and moving it up out of the way (I didn't touch the wipers). The harness connector attaches to the ECM with one 5-point security Torx fastener that remains in the connector once loosened. The security Torx fasteners have a central pin so your bit must have a center hole. I found an inexpensive set on eBay.
Cheers,
Don
Old 03-15-2015 | 09:21 PM
The EEC thank you all very much!!
Old 03-16-2015 | 03:00 PM
JagV8's Avatar
It'll not be faulty...... (well, almost for sure)
Old 03-17-2015 | 08:45 AM
Seems like it will be fun. Ill do it this weekend. Finally getting to it to get it reflashed
trickeyM
02-29-2020 08:00 PM
trickeyM
10-04-2015 06:43 PM
mat32essex
10-03-2015 05:12 PM
zoozth
09-29-2015 08:28 AM
Quick Reply: Where is the computer?
