Where is connected "end" hose from AJ87977 transducer ?
Daimler X350 4.2 SC MY 2006.
I have problem with connecting vacuum hose "end" from transducer on the rail. I make restoration of engine and I lost photos![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Does anyone know where the "end" is involved ? See pic, please.
Photos will be best, but explanation is also very good![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Thanks for the help, Roman.
On my 2005 XJR that vacuum hose connects on the back drivers side of the "spreader" .
By spreader I mean the casting that the SC pushes air up through to both charge coolers.
The connection on my 2005 XJR is almost dead center of the pic.
I have no such connection as shown in Woox's picture. So maybe a change in the 2006 model year.
Item #4 in your diagram sits on the back of the left hand side fuel rail and looks exactly like my car.
Item # 7 on my car is a white T piece with the right angle connection blanked off and going nowhere.
The longer rubber connection leading away from the T piece connects on the back of the "spreader" I mentioned.
That connection at the left hand side rear of the spreader is easy to see with the cover off.
If you do not have that connection then you probably have what chris is showing in his picture.
Does your supercharger coolant top up plug look like this? The picture is showing the top up "hole" without the plug in it.
This top up cast is a dead end at the side nearest the back of the engine and has no other connection other than the rubber pipe at the front.
Sorry I must make new beginnig, I think, that pics are better.
1. Long vacuum pipe
Left hand is clear, but where are going two ends in the right hand ?
"Left hand" beginning there :
Code of the pipe:
2. Where is connected the second pipe from TB ?
3. And what is connected here ? (left and right index finger)
4. Which pipe is conneceted to reservoir ?
Top and LS of the engine:
I'll never lose any photos![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Thanks Roman.
1. Long vacuum pipe
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/03_f35962c4b116d19b4f7d4ea6f8566e8773f2c725.jpg)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/13_5fdd6d3f49e38134e7ba66a262b5dbcf165db6e3.jpg)
Code of the pipe:
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x853/06_be0d68d55495f98b3351f20f7c2faa695d46a973.jpg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/601x451/07_652e3ac50d8b06a348c0cf2179328c1be08f7ddf.jpg)
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/08_cf0cd3b063107c079ba524cf1d42d801898d9c71.jpg)
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/02_f800ad9bc7743192edc34043158a8571a42a9249.jpg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x853/12_bb97d6f8dc07a2510b45eab4a0c7a77dff88cb42.jpg)
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/639x479/11_d5c5a56244edcb37d598a3a5b86f416c11fa40e9.jpg)
Thanks Roman.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
rothwell
12-17-2009 08:09 AM
