where to get body repaired in Northern VA
I tried doing a search first, but couldn't find what I'm looking for.
My car was damaged yesterday - the left rear fender is mangled and the left rear light is broken.
Does anyone know a good place to get body work done on Jags here in northern VA?
Received 2,192 Likes
My car was blasted in the passenger side when I got it in 2005 with 900 miles on her. I spliced 2 cars together and got junkyard and dealer parts to make it work at the local body shop. I took a while sourcing aluminum rivets and the body shop had to purchase an aluminum welder. The car has run without a problem since then. Only issue is after 5 years the body filler seperates from the aluminum, and I had that repaired and re-sprayed a while ago. Good as new. 145,000 miles happy. P.S I saved $25,000 after all was said and done
xjrjag
09-27-2015 01:53 AM
