Where is the MAP Sensor on an XJR?
Received 13,205 Likes
Hi Donzi,
I'm attaching two pages from the 2004 Technical Guide that should help you find the MAP sensor. The diagram shows the supercharged engine as viewed from approximately the driver's seat. The MAP sensor is Part 9 in the diagram. It's tucked down behind the throttle body near the EGR Valve, Part 7. I can see why it would be hard to find!
Cheers,
Don
Cheers,
Don
Is this different to the Workshop manuals? If so, do you have the Technical Guide for the N/A, please? I would like an N/A version of that S/C diagram!
Yes the Technical Guide is different from the Workshop Manual. See pdf pages 90-91 of the document below for the N/A diagram:
Jaguar X350 Technical Guide 2004-2005
Cheers,
Don
Hi EsRay,
Cheers,
Don
Cheers,
Don
The drawings in this Tech Guide are of better quality than those in the Workshop Manual and are also better at showing exactly where the parts drawn are located. I think this is a valuable aid to the Workshop Manual and perhaps should be included in the 'Stickies'?
wartooth (11-18-2018)
adam699
09-12-2015 05:32 PM
