wheres the fuel pump driver module located?
2005 xj8 L restricted performance came on while driving and would not let me accelerate at all. car didn't die but when i turned off it wouldn't restart I'm starting to think its the fuel pump but i wanna check the fuel pump driver module before i change the pump out!
just check for voltage at the pump terminals .
car at won’t start so i can’t get to Autozone to have codes checked but CEL is on and last time it was checked it was misfires on cylinders 345678 so i changed plugs and coils no issues afterward but CEL never reset
I would look at seeing what the fuel pressure is in the fuel rails next if I were tackling this.
There are MANY more related codes so you really need to get codes read. Even buy a code reader yourself to do this.
I use iCarsoft i930 for Jaguar however a cheap ODBII reader would probably pick up these types of faults
P0300 Misfires
ECM to ignition coil primary
circuit fault (cylinder misfire
detected DTC also flagged)
Ignition coil failure
Spark plug
failure/fouled/incorrect gap
Fuel injector circuit fault(s)
(injector DTCs also flagged).
Fuel delivery pressure high/low
Fuel injectors restricted/leaking
Fuel injectors continuously
open
Fuel contamination
Worn camshaft/broken valve
springs
P01901 fault
Fuel filter/system restriction
Fuel system leak
Incorrect fuel pump output
FRP sensor to ECM sensing
circuit; high resistance,
open circuit, short circuit to
high voltage
FRP sensor to splice in sensor
supply circuit; high
resistance, open circuit
ground circuit; high
resistance, open circuit,
short circuit to ground,
short circuit to high voltage
FRP sensor failure
P0300 Misfires
Spark plug
open
Fuel contamination
springs
P01901 fault
Fuel system leak
high voltage
FRP sensor failure
so just bought a replacement fuel pump and still nothing when i Turn the key to position 2 pump doesn’t do anything
Anyway, I'm at a loss here.
Well, Found out something new the other day. Took the pumps top half off the tank, Checked the actual pump its self, To find the ground wire I suppose, next to the white wire on the pumps connection in the harness was just dangling there. It apparently was so worn it just slide out like it was nothing! Seemed corroded some.
So, After pushing it back into the pump, The pump would turn on, But it clicks, not hums or runs any. So, I'm assuming the link fuse in that line is shot?
Its a new pump! So it has to be the only thing stopping it! The pump does spark some on that worn wire if pressed in, so it gets juice just nothing to get it going.
