White smoke and (possibly) oil in tailpipes!
Hello,
So last night I replaced my PCV valve in my 2004 VDP. Started up this morning, started driving to work, started getting very large plumes of white smoke from tailpipes. I mean REALLY large amounts of smoke... so much so, that I pulled over and turned off engine. Opened the hood, checked the coolant, saw that it was a bit low. Checked the oil, it too was a bit low. Checked the tailpipes, and the pipe on the driver's side had an oily, black liquid at the end of the exhaust pipe. Is it possible that the new PCV is bad? Would this cause the smoke?? I occasionally got small amounts of white smoke prior, but usually went away quickly.
Thanks in advance for any advice!!!
My mechanic friend thinks it may have sucked oil in and stuck in the corrugated pipe network. Weird, because it must've sucked in quite a bit... at least a quart, based on when I checked it on Saturday til today. Don't see any water/coolant in oil.
it smoked this morning, and also this afternoon when I moved it a bit for towing. Smells like oil in tailpipe... and black. Also, coolant level is steady... a bit low, but nothing to suggest the kind of smoking I was having. But burning white smoke. At least it looked white to me... maybe it was bluish?
Going to take new PCV off tomorrow and start there.
Azartist, Don't know if this will be of any help to you in deciding what is causing the white smoke, but when (a while ago) I had huge plumes of white smoke out of my exhausts I also had a strong smell like burning rubber? I put some of the Synthetic oil we use into a small tray and heated it and it gave off white smoke and smelled of burning rubber....
Without know where the coolant went or the oil, there's no other efficient way to source the problem.
Again, if it's my car and assume my leak down test passed, I do a coolant test to find out where the coolant went. Not germane to your problem if it passed the leak down tests but something I'd want to solve.
Then I change my oil and do what meiron1 suggests.
I assume you have no DTC codes?
I will assume that is something my mechanic will pursue this weekend. I guess at this point I am hoping that it was a faulty PCV that I installed, as this all happened the morning after I installed new PCV the night before... rather than a blown head gasket.
I am also going to see (hopefully) where I'm losing coolant... not much gone, but enough for concern.
Compression was consistent across all cylinders. Really stumped with this. Can't find where/how oil is being sucked. Was sure the culprit was the PCV valve, seeing as how the smoke/loss of performance didn't happen until PCV was replaced. Bought and installed 2 of them, thinking first one bought online was defective... second one from a Jag dealer. No difference. A sh*t-ton of smoke, and very poor performance. Sucking oil through and out back like crazy. Undriveable. Such a beautiful car, but man, nearing my wit's end with this.
There is a possibility that you are getting a very rich fuel mixture either due to a leak in the intake area, faulty O2 sensors and or dirty MAF.
The "oily" fluid in the tail pipes could be unburnt fuel mixed with oil vapor from the cylinders.
When I installed 200 Cel Catalytic converters I used front O2 sensor mini cats that moved the sensors out further from the exhaust.
When I accelerated I produced a LOT of white smoke.
When I put the O2 sensors in normally problem resolved.
So my issue was O2 sensors not reading correctly.
Azartist (11-16-2018)
