whole control arm or just bushing?
Hi 04 xj8 has had clunk noise when hitting bumps since I got it last year. Local brake max showed me the play in the lower control arm big bush where it mates to the frame. They say the bush cannot be replaced, must buy whole arm at $600+each. Yet many parts sources including dealers show the bush as a $60 item. Can it be replaced without destroying the control arm? Some people on here state bush only can be replaced while keeping old arm. What is definitive final answer on this please? Thank you.
PS: relevant part number is c2c4437 I think.
jackra_1 (11-26-2016)
Yes, a useful tip and one I also heard about.The aluminium expands twice as much under heat as steel so the gap for the bush to fit into will enlarge and ease the process. It also works on the removal of the old bush too.
