Will not start - immobiliser
Hello, hope somebody on the forum can help before I have to take car to Taggarts.
I have a very nice Jaguar XJ6 3.0 V6 auto 2003.
I had to have the ecu replaced as it got water damaged.
Got a ecu with the same serial and had it programmed. now car will not start, nothing at all starter will not turn so I am guessing its the immobiliser.
I have searched the internet and tried the trick where you reset the immobiliser by touching the earth and positive battery leads also tried the trick where you leave the battery negative terminal off for 30 minutes. I have checked the voltage on battery shows 12.08v doors open and lock via remote. Many thanks in advance
damaged, ecu, immobiliser, immobilizer, imobilizer, jaguar, problem, reset, start, tdvi, water, wont, x350, xj8, zj8
