Will these fit my '06 XJR?
I'm looking for a winter set-up for the '06 XJR. Tire Rack suggests 255/40-19 (19 x 8.5 wheel) or 235/50-18 (18 x 8). I'm trying to determine if the wheels / tires this member has for sale will fit my car. They're from an '09 XKR.
https://www.jaguarforums.com/forum/p...-wheels-60604/
Can anyone tell me if these will work - I'm concerned about brake clearance of course. Thanks in advance.
Ken
Ken
im confused because I thought all current body style XKs had a staggered set up.
anyways, 18" should still clear even with the brakes because they are the same set-up as S type Rs with the same brakes. id check with the dealer to make sure.
on XJs however you can not do a staggered set up. the computers are designed for all 4 wheels and tires to be the same spec and it will drive the ABS crazy if not.
hope this helps!
hope this helps!
metalmarty
09-11-2015 07:05 AM
