Window problem
Hi Guys,
I have a little problem with my right rear door glass, the switch on that door works perfectly, press for down, window goes down, press for up, window goes up, as you would expect. If I use the switch in the drivers door for that window, press for down, window goes down, however, press for up, the window goes DOWN. I thought perhaps it was a bad switch, so I finally got hold of a drivers door switch pack for a nice low £20 off Ebay, popped it in today and still the exact same results.
Now I know it's not the end of the world, and as it's a right hand drive car, I can simple reach behind me and use the rear door switch to put it up, but it's niggling at me and I'd like to fix it, I don't suppose anyone has any ideas of what is causing this?
nd4spdlsc
11-26-2019 07:43 PM
Leichardti
09-06-2014 04:35 PM
Jag Pilot
07-04-2013 10:09 AM
