Window won't close
Hi All
My X350s latest peculiarity is to not allow me to close the passenger ( Left side) front window. The window opens with no problem from either switch or by using the window opening feature on the key fob. When closing however if I fiddle with one of the switches it closes a bit at a time. Holding the switch in the close position has no effect but sort of tickling it produces random jerky movements in the close direction.
The wiring diagram shows a motor regulator and a position sensor but gives no indication as to where they are.( maybe combined with the motor)
It seems to be a switched earth arrangement so my next move is to take the door card off and jump an earth lead directly to the motor terminal to prove the switches.
Any ideas and theories most welcome.
Pete
Pete
