Windshield trim won't stay on
2004 VDP. The windshield trim clips into these plastic clips that appear to be embedded under the windshield. I think one is missing, one is cracked and the last one just won't hold the trim down. I cannot be seen driving my VDP around with masking tape holding the trim on. Anyone have experience with this problem.
If you decide to go the clip route I have all of them available.
I also has a 2004 VDP. About 4 of the 10 trim clips have broken. I have 4 new clips but now I think I should replace all 10, there all old and brittle. I am trying to figure how to get the broken clips out so I can slide the new ones in with new butyl.
I also want to repaint the metal molding. I prefer to remove the rubber parts. The inter ones came off easy. They have a female channel in then that slides over the male channel in the metal molding. I think with some lube is should be easy (I hope).
The outer rubber molding has a male profile the slides into a female profile in the metal molding. The appears it might be a problem. I could mask it off but re
moving it would do a better job. Has anyone done this successfully?
