Windshield washers
I had this a few years ago on my X350 and did exactly the same things as you have, in the end the car was going into the garage for something else and I asked them to look at it,I wondered if the impellers may have broken in the pump as I could still hear the pump working, they removed the washer bottle and cleared it out, they said it was clogged up really badly in the bottom and this was restricting the flow, they cleaned it thouroughly and three years on it is still fine.
if so, how does that fix the problem?
i'm not understanding... is it that the pressure build up would be able dislodge something blocking the tubes?
