Winter Storage | What to do?
I have stored my mustang every winter (about 5 months a year) and I have only parked the car in the garage. The only problem I have seen in 10 years is not keeping the battery charged. Most newer cars have computers that draw current even when not running. A battery will discharge by itself if left too long. I now keep a battery tender on it if I know it will be in storage longer than a month. Most people will say you should change the oil before storage because old oil becomes acidic. Keep the tire preasure up or even a couple pounds higher. The preasure will go down when the temp gets colder. A big misconception is some people say to start the vehicle once a month to keep parts lubercated. You don't want to do this because the tempurature change from inside the engine to outside the engine will cause moisture to form inside. You need to than run the engine long enough to evaporate the water. Just my $.02
For 90 days I wouldn't do much of anything. Start it and run it for 5 or 10 minutes every 7 to 10 days if you can arrange it. If you can run it around the block on good days just to change the at rest position of the tires you will avoid temporary flat spots. If that's not possible and you are real picky, jack up all four corners to get the weight off the tires/suspension. I presume this is Winter storage you are contemplating.
If it were mine, I would not disconnect the batt. or jack up the car or change the oil for a 90 day storage situation. Anything longer and you may want to take more extensive measures.
I won't be able to do anything but just park the car and forget about it. There's a slim a chance I could go to start it up and drive it once or twice, but the car is 80 miles from my house. I am most worried about flat spots.
Are the flat spots really temporary? I had them once on my Merc and they did not go away.
Received 2,263 Likes
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
NICE POST BTW!
i remember storing my Xj SuperV8 last winter, disconnected the battery and that was it,when i went back 5 months later to pick it up ,to my suprise the whole front end was completely down. i think that was due to the air suspension. after starting the car the front end raised to its normal height. this year to avoid having all the weight of front end sitting on tires and mags, i installed a jack under its jack points at the front end only. the jack was installed so when front end will slowly sag, it will sit on the jack and take some stress off tires .
Living in Montreal i have stored my cars every year, just add gas stabilizer and increase tire pressure.never had any problems. mind you they always been stored in heated garages.
Same day Disco stu 55 buggered his X up, I was driving around in my new to me '99 Durango. Looks like what I paid for it was less than what Disco will have in repair bills. My X-Type is now sitting in my heated garage. The temp is kept around 50 degrees but Mama-bear's Jeep will be in and out so there will be moist air in there. I don't think I will take her out again until spring. Battery tender and fuel stabilizer, 50 lbs in the tires, and I should be fine?
Received 9,010 Likes
![Name: car01.jpg
Size: 19.3 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/180768d1501306742-winter-storage-%7C-what-do-car01.jpg)
WINTER CAR STORAGE TIPS
As most of you probably pack your favorite ride away for the winter, the followingwinter car storage tips can be used to maintain the integrity of your car andminimize any damage from improper storage.
1. Store your car with a full tank of fresh gas to minimize condensation of water. But before you fill the fuel tank up, add some gas stabilizer to the tank prior to the fill up. Drive the car for a few minutes to ensure that the gas stabilizer is throughthe entire fuel system. Change the engine oil and filter. This will help assure internal rust and corrosion protection and reduce sludge buildup.
2. For water cooled cars, flush and refill the cooling system with new coolant if needed (typically every 2 years for the green stuff and every five years for the newer orange stuff (Dexcool)).
3. If you have not flushed the brake system in the past two years, now is a good time to flush and refill the brake fluid. Get another person to help out and work from the farthest to the closest wheel from the master brake cylinder.
4. Top off the transmission and differentials with appropriate lubricants.
5. Spray WD40 on all hinges (hood, doors, trunk, etc). It is also a good time to lubricate door latches, handles and key cylinders.
6. Wash (and wax) just prior to storage.
7. Clean the interior, and dress all vinyl and rubber with appropriate treatments.
8. For soft top cars, put the top up. For all cars that are being stored inside, leave a window or two down slightly to allow air to circulate into the interior.
9. Jack up the car and place jack stands so as to relieve weight from the springs and prevent flat spots on the tires (more common on older bias ply tires).
10. If a cover is used, use only soft cotton or comparable material that breathes and allows air circulation.
11. To absorb excess moisture, place a couple bags of desiccant in the interior of the car and one or two in the truck. This will help minimize condensation, rust and mildew damage to interior materials.
12. Disconnect the battery while the car is in storage. To prolong the life of the battery, attach and plug in a battery trickle charger. Letting a battery sit too long and discharge is a quick way to ruin it in a short time
