Wiper hang up on a 2004 XJ8
Old 04-16-2011, 01:08 PM
red66's Avatar
Default Wiper hang up on a 2004 XJ8
Just Bought a 2004 XJ8 and noticed that on occasion the wipers when they should return in the park position (bottom) seem to get hung up across the middle of the windshield. this happens on all settings. Most noticeable when turn off the manual modes or in auto mode and it tries to park itself.
I engage it for a single swipe or when I turn them off in a manual mode I end up having to re engage the single swipe mode until it ends up out of the way. I am wondering if perhaps there are some gears in the mechanisms or some kind of clutch that may be at fault.
has anyone seen this or is this a common issue?
Thanks in advance
Old 04-16-2011, 01:45 PM
DB6's Avatar
DB6
DB6 is offline
ud
It is a common problem; a cheap fix that might work ( it did for me) is the repacement of the two relays in the box on passenger side under hood(@ $16.00 I think);others on here have had the wiper motors replaced(expensive).
Old 04-16-2011, 03:16 PM
diverguy's Avatar
Talking
This past winter I wished I had your problem:-) - I wanted to fold out my wipers from the windshield so that they wouldn't freeze to the glass but never found out how to - even asked a question on this forum...
/Mike
Old 04-18-2011, 12:05 PM
red66's Avatar
Thanks I'll try the cheaper path to see if I can remedy w/o changing the motor provided I can find the relays , I'll let you know how I make out.
Old 04-23-2011, 11:42 PM
red66's Avatar
Question I looked at the Relay's for the wiper hang up issue and I saw somewhere else that the wiper relay was Relay #4 & #8 (under the hood) looks like #4 & #8 are the same part #, I was wondering if anyone could confirm that in fact #4 & #8 were the wiper relay on an 04 XJ8 and if so my #4 & #8 part number is LJA6707AA I am curious because I saw #4 & #8 as a suspension parts in another post (I realize this could be be more then 1 system handled by these relays). This same post claimed that Part # LJA6707AA was replace by Ford part #'s V231136-A1-X64 or 5M5T 14B192 DA or 02C234433 in another the first & 3rd I could not find and the second seems to only be in Europe. Can anyone tell me anything to clear all these items up? Thanks for any clarification in advance, Thanks in advance...
Old 04-24-2011, 12:38 PM
DB6's Avatar
DB6
DB6 is offline
ud
Default call the dealer or parts place
and have the thing in hand with a pic of where it came from, they will get you the right ones.
Old 04-24-2011, 08:18 PM
jaglover922's Avatar
At first we were replacing the wiper motors. But the real issue is that I would check before doing that is take some connector electrical cleaner, and clean the wiper motor connector. Then I would clean the ground on the passenger side by the cabin air filter. The cowl or plenum cover will have to come off. The cabin air filter box will have to come out, I believe. The wipers are parking midway, The relays have nothing to do with that. There is only a wiper relay for fast/slow, and for wipers(operation period), the parking of the wipers is built into the motor. Lastly, the wiper motor is pain in the you know what to do. I would start with the connector and ground cleaning first.
Old 04-25-2011, 07:22 PM
DB6's Avatar
DB6
DB6 is offline
ud
Default In my case the relays solved it
Not saying you do not have a point Lover but in my case the relay change did fix it, it was always an odd fault and intermittent anyways.
Old 04-25-2011, 09:23 PM
brdave's Avatar
Dealer just changed the wiper motor in my car under warranty. I understand that it was a hatefull job to change the motor but did resolve the problem.
brdave
tomsjag
06-10-2023 10:02 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
Jackieo123
09-14-2015 09:03 PM
mhenz
09-14-2015 07:47 PM
jimbo1948
09-07-2015 03:14 AM
Quick Reply: Wiper hang up on a 2004 XJ8
