Wiper Replacemnt
Wiper Replacemnt
Jaguar X350 2007.
Is there an easy way to replace the wiper blades on this model?
The arm does not lift all the way up like it would do on most cars due to fouling on the edge of the bonnet.
Is it possible to stop the wipers at vertical to allow the blades to be changed easily - without removing tha battery that is!!
Seems to me as though the may be a hack for this that the dealer would use when it is time to replace wipers as it seems a bit of a pain of a job from what I have seen so far.... Don't really want to go down the road of removing the wiper arms either but that is what I am considering at the moment!
Cheers...............
Had a play with these at work this evening and they actually come off fine - a bit of a fiddle but they do slide off in exactly the same way as any other blade, rather than being vertical you just have to slide the wiper along the line of the windscreen once you have released the hook from the clip on the blade and off they come!
I bought some BOSCH Aero blades that have the washer nozzle already attached from Euro Car Parts (UK) for approx. £25.00 an they have done the job spot on!
I've changed the blades many times without "parking the wiper arm. Thats because you cannot park the arm mid point on a X350. The last post doesn't park them either. If changing the whole blade assy, you have to open the bonnet to get the arms up high enough to remove the whole wiper assy.
