Wiper Washer Stopped Spraying
Hello. I have a 2006 Jaguar XJ8. A few days ago, the wiper washer sprayed just fine. A day or so later, it sort of spirted, then stopped. I assumed that it needed to be refilled. However, after filling, the washer is still not spraying. Every once in a while, I get a small spritz, mostly right at the start. But for the most part, nothing. I can hear the pump running when I press the button, so that appears to be (trying to) work. Could it be a clog in the line somewhere? What's the best way to diagnose this?
Thanks.
Thanks.
Try blowing compressed air back down the water tube ...
Edit - Did it and it worked a treat! Thank you so very much.
J.A.G. (10-02-2021)
Rickkk
03-10-2022 08:22 AM
JagX350
05-22-2017 03:55 PM
