Wipers Advance Only Half Way
Mine: 2008 XJ8L - I turn on my wipers for continuous swipes and the first few, 2 - 4, swipes work fine. On the next swipe, the wipers stop half way. Pulling the lever as you would for a single swipe continues the swipe and returns the wiper to the start position. Any ideas as to what's going on and how to fix it?
Thanks,
Brant Weatherford
2008 XJ8L
1969 XKE FHC
1963 Cushman Iron Eagle
Thanks,
Brant Weatherford
2008 XJ8L
1969 XKE FHC
It could be several things:
- wiper shifter
- FEM
- grounding points
- park switch inside the wiper motor
Unfortunately, it is most likely the last reason. Getting out the motor is PiA, You need to dismantle the cowl cover, brake booster, disassemble the motor. Finally, the most annoying thing: the starlock protection inside the motor cover. This is detailed written somwhere on this forum, pretty common glitch.
- wiper shifter
- FEM
- grounding points
kbeachy
04-19-2017 08:21 AM
