X350 2-Pin Throttle Motor Connector Pigtail - Found Match
Just wanted to let everyone know that GM AC Delco PT2048 is an exact match for the throttle motor connector (2 pin TB connection) on the X350 throttle body. Mine deteriorated and crumbled a while back and the terminals eventually rattled loose. After a lot of searching through Google images of 2-pin connectors I finally found the AC Delco part number and soldered it on tonight. Fits perfectly, weather seal and terminals are included in the kit... Hope this helps others.
$33 On Amazon
$33 On Amazon
