X350 4.2 2004
X350 4.2 2004
Hi
Where would I go to find a fault when the height adjustment of the headrest on the driver's side seat does not work. You can hear a click under the bench when you push the knob either down or up. The height adjustment of the headrest of the passenger side seat works flawlessly.
Best regards
Pekka
Finland
Best regards
Pekka
Finland
Now the headrest started working intermittently. That is, when the headrest is in the middle position and I try to put the headrest down, and I press the button, the headrest moves intermittently. Pressing the button is of no use if you press it continuously. The headrest only moves up or down intermittently. Is there a problem with the headrest motor or is it possibly worn out?
MLippens
02-11-2020 03:02 AM
