X350 aircon condenser change
Old 05-22-2023 | 09:44 AM
xj40s's Avatar
Default X350 aircon condenser change
Anyone know how difficult it is to change the air conditioning condenser on a 2005 4.2. Any particular snags or tricky bits?
Old 05-22-2023 | 05:04 PM
mhamilton's Avatar
It's not very difficult. You can do it by removing the lower splash shield and the grille. There's 2 nuts securing the condenser, and 2 slots that keep it attached to the radiator. I believe the p/s cooler shares the same studs as the condenser, it can just hang while the latter is changed.
Of course usual caveats about discharging the refrigerant first. You'll also need the 2 orings for the condenser inlet and outlet. They are not standard sizes I had in my a/c oring assortments, I ended up ordering from the dealer.
Another small gotcha, the Behr condenser I ordered should have been OEM, but arrived as unpainted aluminum. Giving that a quick flat black spray caused unexpected delays.
pkoko
26
10-23-2022 08:56 PM
MaxTorq
01-08-2022 12:10 AM
dalo
12-15-2020 02:08 PM
dwdooley
10-25-2018 10:52 AM
Quick Reply: X350 aircon condenser change
