X350 car phone and radio dead
I was out in the car last week all was fine, radio playing etc and got a call on the car phone via my Iphone.
Took the call and the radio went off as normal, call ended and the radio came on again. Parked the car and came back one hour later the radio wouldn't come on at at least the sound wouldn't. When I pushed the phone button on the steering wheel 'mute' came up on the display. I pushed the phone button on the dash and it came up saying no phone fitted to this vehicle.
I checked the phone in the centre console and it is dead. My thoughts are that this is what is causing the radio to not produce sound.
So now I have no phone and worse no radio.
Anyone got any thoughts on how to sort this out?
Dave
Dave
Hi Dave,
Have you tried re-pairing the iPhone? You may have to un-pair it first using the manual. Regarding the radio, you may try turning it off using the knob on the lower left center console and then turning it back on using the center console screen. You may also see if your sound system plays cds.
The phone is stone dead nothing on the screen at all so pairing it isn't an option. It looks like the phone has muted the radio and CD player so nothing works or it may work but the sound is muted.
Pushing the phone button on the dash gives a display which says " there is no phone fitted to this vehicle"
I think it's fairly obvious that the phone is at fault so I need to see where it's powered from and start from there, anyone know?
Dave
Dave
Try electrical reset. Disconnect the battery for one minute. All modules should return to default settings. That's where you have to program your seats and windows and do a drive learn for the power train module.
Note, it should not effect your radio stations setting. Let me know if that helps.
Bluetooth unit is Motorola is under the center console glove box liner.
Pull out the liner you will see little box Velcro to console. They do cause problems.
Let me know if this helps.
George,
I'll give that a go, I was going to give my car a service at work last week and thought about a hard reset but decided against it in case the car went into terminal meltdown and wouldn't start again
I'm now doing the service between Christmas and New Year, new front rotors, pads, all the filters,oil and the biggy the transmission oil pan/filter change.
Dave
Dave
The phone is still dead and the radio muted.
I checked all the fuses and they are all good so really don't know where to go next.
Dave
BrentGardner
28
04-26-2024 03:08 AM
msdg137
09-16-2015 06:24 AM
Andrew McVey
16
08-27-2015 07:21 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
