X350 cooling fan
Guest
Posts: n/a
Does anyone have any information on how the fan is controlled
and what type it is ?
it appears to be a brushless DC design, but how is it controlled by the computer ?
PWM ? CANbus ?
![](http://www.coastalboatsales.com/jfraley/jagfan1.jpg)
![](http://www.coastalboatsales.com/jfraley/jagfan2.jpg)
part number is:
930-0015-11 ( I think)
so there are four connectors
obviously the two large ones are power and ground
and the two small ones are control.. but is one data/PWM and the other feedback (like RPM )
or both data etc...
PWM ? CANbus ?
part number is:
or both data etc...
![](http://www.coastalboatsales.com/jfraley/jagfan3.jpg)
Guest
Posts: n/a
sorry, I am a bit confused...
I think what you are saying....
large connector: (on right in photo)
right conductor in photo - Brown/green stripe - large 10GA wire - Ground
left conductor in photo - Black - large 10GA wire - 12V+ power to fan
Small connector:
right conductor in photo - White/Blue stripe - small 18GA wire - 12V+ power to module
left conductor in photo - Green/Blue stripe - small 18 GA wire - PWM from ECM
you say it is definitely controlled with PWM ?
thats great !
do you have any other information on the PWM signal ? does it just control RPM ?
frequency range ?
thanks !!
Small connector:
thats great !
frequency range ?
thanks !!
Andrew Pearce
11-02-2015 02:35 PM
