X350 Interior Lights
I was looking at replacing all my interior lights with cool white LED's, but after experimenting decided I really like the stock "soft" lights.
For your reference a 2004 XJ8 has the following interior (and a few exterior)lights:
Outside
license plate (qty 2) 194
under side mirrors* (qty 2) 194
Inside
door mounted lights (qty 4) 10x36
front under dash lights (qty 2) 194
rear floor lights (qty 2) 10x36
front overhead lights** (qty 2) 194 and (qty 1) 10x36
rear overheads*** (qty 4) 194
glovebox (qty 2) 194
trunk (qty 1) 10x36
*Push mirror towards front of car and light compartment pulls out away from car. (Thanks to FactoryJaguarTech for this info.)
**The cover is on there pretty good, but you just need to be patient and pull hard.
***This is the only place where screws were required to be removed (mostly holding the handles). None of the other lightsrequire screw removal to get to them.
194 = wedge base 194 style bulb
10x36 = festoon style bulb that measures 10mm dia and 36mm length
Not terribly likely that anyone will need this info, but figured I'd document before I forgot.
Outside
Inside
trunk (qty 1) 10x36
Marc Gai (07-10-2022)
rsa760041
23
09-25-2015 01:33 PM
