X350 Speaker sizes
Hi guys,
I'm looking for same information and since the link doesn't work anymore, anyone else have any info?
Tried to find online to no avail...
I need to replace practically all speakers (teenager son blew them out...) and would like to get the sizes so that I can go and buy some aftermarket speakers.
Thanks in advance.
Thanks in advance.
Factory size is actually 6.75".
You can fit any 6.5" aftermarket speaker, using speaker adaptors like I did in my X-Type. Have a look at PVC Speaker Adapters - CNC Machined - In Stock or Custom Made and there are pics of my install Retrofit OEM Amplifier & Speaker Upgrade FAQ
The midbass speakers are the same as what's used in the X-Type, and one of the guys said that Sony xplod bolted straight in OEM Speakers or Aftermarket Ideas?
Number of speakers depends on which system you have, Standard, Premium or Portfolio.
Wiring diagrams for the X350 Standard & Premium Audio System HERE
There is a different system in the Portfolio (with a 2nd amp for the midbass in the front doors) but I don't have a wiring diagram.
Standard (called Premium) is 8 speakers; 6.75" midbass + tweeter in each door. Running off the 4-channel 140W head-unit only.
Premium (called Audiophile) is 12 speakers; same as above, plus two 6.5" subs, and two mid-range speakers on the dashboard, up near the windscreen. I don't know what size they are but I guess around 4".
All 12 speakers are run off an 8-channel 320W amp in the boot.
Portfolio (from the Super V8 Portfolio) is 15 speakers, same as Audiophile, plus two mid-range on the rear parcel shelf, and a center fill speaker in the dash. There is a modified version of the 8-channel 320W amp, plus an additional 80W amp which drives the mid-bass in the front doors only.
Has anyone put anything like this JL Audio C3-650 Evolution C3 Series 6-3/4" convertible component speaker system at Crutchfield.com into their X350 as replacements to stock?
Are the stock electronics of sufficient quality to warrant such an upgrade to the speakers alone?
I know this is old, but it ranks high in a google search, so I'm going to add to it.
Just FYI, the dash speakers in my 2006 SuperV8 (Audiophile, HA!) are 2.25" or so in a 2.5 basket with mounting holes 180degrees opposed at 3 inches. The numbers on the back of mine are:
2W93-18808-EB
5056WH
They say made in China, and they mean it!
2W93-18808-EB
5056WH
Eurocharged
09-22-2015 02:17 PM
FS[NorthEast]: 2008 XKR Portfolio Convertable
Knomad
09-22-2015 04:36 AM
