x350 Speaker System - Crutchfield doesn't know
So I have read everywhere that Crutchfield is the place to go for speakers... however it says "Sorry but we haven't researched this part of your vehicle" when I plug in my 07 XJR...
I know I have the 12 speaker Alpine kit, and am guessing another model of Jag's for 07 had it as well X-Type maybe?
Can anyone confirm another model that would have the same kit, and preferably has been researched by Crutchfield so I can browse their selections...
I've seen some posts on here for kit, but most involved replacing the AMPs and head-units, and that's not what I want to do... just the speakers... so i was hoping to use crutchfield's part browser to identify easy replacements.
The speakers are 6.5" but you will struggle to find one that slips straight into the existing hole.
When I did the stereo install on my X-Type I bought some speaker adaptors which were basically a perfect fit with aftermarket 6.5" speakers. PVC Speaker Adapters - CNC Machined - In Stock or Custom Made
As mentioned above the impedence of the speakers is a bit of a mystery. And in hindsight i'm sure they aren't regular 4ohm or 8ohm units.
The problem is more in regards to the tweeters, the stock tweeters have a capacitor on them which functions as a filter (like a crossover) and i suspect that the stock tweeters are a much higher impedence to somehow attenuate the level compared to the midbass drivers.
Using Focus 6.5" splits I had the problem of the tweeters being way too loud and the system was not properly balanced.
I would stick with stock speakers, or at most go aftermarket midbass but leave the stock tweeters. Unless you can find 4ohm midbass & 8ohm tweeters.
That's just a guess to the impedence btw...but i think it must be something like that, based on the experience I had with the X-Type install...
Have a look here https://www.jaguarforums.com/forum/x...ade-faq-64614/
I bought 4 of these CDT Audio CL-6EX in 2 ohm to replace the mid-bass on my XJ8 my car doesn't have the amplifier but has tweeters in the dash and door handles
I bought the speaker adapters Cambo recommended
I haven't installed them yet to busy with work and the wife's Jeep is of the road at the moment so she is using my XJ8 ( I could kill Jeep for taking so long with the parts )
So, the next question is, where's the best place to source the stock parts? I've found Jaguar Merriam parts to be the best place to buy parts online. But is there a less expensive place to source straight Alpine units?
MSRP on the stock tweeters (premium sound) is $83. (!!) And I need 4 of them.
The stock are very cheaply made
I need new tweeters. On some solo piano pieces, I can hear distinct distortion coming out of some of them. I'm also an audiophile, and I know how critical it is to match the system and the crossovers (some of which I think is embedded in the digital head unit), so I think I'm going to take your advice and stick with stock. Stock actually sounds very nice.
Most were damaged. I had a local stereo shop go over it. They replaced the door speakers with component 6 1/2 set from AD Degign. The tweeter has to be modified to fit in the door handle. They fit the mid driver easily.
The subs are tougher. They are 61/2". The stock one weights next to nothing. The used some Kicker 6 1/2 subs. These are not very good either.
I guess a ride in a well maintained x350 is needed on my end. The Alpine system was damaged, not sure how good it sounded when working properly.
