x350 Supercharged runs poor cold, misfires on one bank
Received 2,190 Likes
Probobly injectors, send them out and have them cleaned i use these guys
WWW.injectorrx.com
the 10% methanol creates deposits and cold start issue. Ive even tested and foubnd gas that contains alot more than 10%. But you have no idea of whats going on with injectors without having them tested, cleaned and screens replaced. And @ $18/injector its cheap diag, elliminates guessing, and thinking your gonna do much with tank or on board cleaners is a big waste when you have problems that you suspect might be injectors
WWW.injectorrx.com
Interesting. Injectors wouldn't be my first guess with no complaints of top end performance or acceleration. I have never seen a fuel injector so bad that it will cause a bad misfire at start up then just go away. I could be wrong.
Also its about a 9 hour job to remove a fuel injector in SC 4.2 so unless I know for sure I cant really say its a cheap diag.
I am leaning towards the upstream fuel/ratio sensor on that bank.
Wolfy
05-28-2024 08:06 AM
KarimPA
09-12-2015 08:15 AM
