X350 V8 model 2006 Speedometer problem
Old 01-13-2018 | 04:52 PM
ERNA's Avatar
Default X350 V8 model 2006 Speedometer problem
Hello
My brother in law drives an XJ8 (LHD) Sovereign model 2006.
It is now the third time the speedometer needle does not go all the way back to "0" and when the car is motionless the speedometer needle is "stuck" at 30 km/h.
When it happened before we simply disconnected the car battery and it was "reset".
As it is now the 3rd time this has happened we are looking for a more permanent fix.
Anyone experienced a similar problem? Any recommendations as to what can fix it?
Many thanks
Erez Nachtomy
Old 01-14-2018 | 08:07 PM
JBzXJ40's Avatar
May need to take out and disassemble - mechanism behind that holds needle in place might be loose.
Cam across this issue on a XF once, had sent out to be repaired.
Old 07-28-2022 | 07:11 PM
MBJAG's Avatar
Mine is doing the same. Battery is already disconnected and the needle stays at 30 mph. I drive at 35 mph to work, needle was at 70 mph. It just started today, funny thing this morning I saw the instrument cluster and though: "what a wonder all these instruments work even though I don't anything about this car previous history".... well Jinxie strikes back.
Jaguri
16
07-16-2024 05:59 PM
Terry007
05-19-2022 08:24 PM
Javlin1961
12-26-2021 11:22 AM
orangeblossom
08-17-2018 01:30 PM
samevo8
01-07-2015 08:25 AM
Quick Reply: X350 V8 model 2006 Speedometer problem
