X350/X358 - 'How To' / DIY Repair & Maintenance
Introduction
This is a replacement for the original “sticky” which developed over a number of years with contributions and suggestions from many members. Broken links in these have been repaired and the random order of content is now categorised. There's also several new additions.
Section headings are in alphabetical order. Links are either to forum threads or to MediaFire online file storage.
Information or links will be added to this first post as more threads, procedures etc are identified and recommended. Please make suggestions by forum post or PM to a Moderator and we can add further links with "thanks" to contributors.
INDEX
1. ACCESSORIES
2. ACRONYMS & ABBREVIATIONS
3. AIRCON & HEATING
4. AIR SUSPENSION
5. BRAKES
6. DTC (Diagnostic Trouble Codes)
7. ELECTRICAL - GUIDES
8. ELECTRICAL – REPAIRS
9. ENGINE
10. FUEL SYSTEM
11. HANDBOOKS - OWNERS (Driver’s)
12. INTERIOR
13. KEY FOB/REMOTE
14. MAINTENANCE SHEET
15. OEM – Original Equipment Manufacturers
16. PARTS - JEPC and S N G Barratt
17. PHONE
18. TECHNICAL GUIDE
19. TRANSMISSION
20. TSB (Technical Service Bulletins)
21. WORKSHOP MANUAL – Complete
22. WORKSHOP MANUAL – Sections
1. ACCESSORIES
Accessories Brochure - 2009
https://www.mediafire.com/file/1ee1l...ories.pdf/file
https://www.jaguarforums.com/forum/g...9/#post1161835 (thanks to Don B)
3. AIRCON & HEATING
HVAC Blower Control Module - Diagnosis & Repair
https://www.jaguarforums.com/forum/x...er-quit-62390/ (thanks to Glendoramike)
HVAC Blower Control Module - Rebuild with New Heat Sink
https://www.jaguarforums.com/forum/x...2/#post1058751 (thanks to Don B)
4. AIR SUSPENSION
Air Suspension & ECATS System Summary: Components & Operation
Air Suspension & ECATS Summary (thanks to Don B)
WABCO ECAS Sales Brochure
https://www.mediafire.com/file/3sih1...037-2.pdf/file (thanks to Don B)
Air Suspension & ECATS - Jaguar Dealer Service Training Manual Extract:
http://www.mediafire.com/view/7rdkgg...on_Section.pdf (thanks to Don B)
Air Suspension Coil Conversion Observations & Tips (thanks to Don B)
https://www.jaguarforums.com/forum/x...s-tips-260716/
Actively seeking Suspension solutions:
https://www.jaguarforums.com/forum/x...p-1-3-a-10574/ (thanks to JagtechOhio)
Air Spring Replacement – DIY
https://www.jaguarforums.com/forum/x...24/#post190851 (thanks to tarhealcracker)
Front Air Spring/Damper Cutaway Dissection Photos
https://www.jaguarforums.com/forum/x...t-away-143111/ (thanks to reyesl)
Lower Your X350 - How to
https://www.jaguarforums.com/forum/x...ur-x350-75369/ (thanks to Cambo)
5. BRAKES
Brake Bleeding - How to
https://www.jaguarforums.com/forum/x...kes-faq-51666/ (thanks to u102768)
Brake Pad Replacement - How To
https://www.jaguarforums.com/forum/x...e3/#post409524 (thanks to edobernig)
Brake & Disc Pad Options - BREMBO
https://www.jaguarforums.com/forum/s...r-x350-103513/ (thanks to Cambo)
Parking Brake Piston Retraction - How to
https://www.jaguarforums.com/forum/x...action-145571/ (thanks to Don B)
Complete DTC Summaries (thanks to Don B)
https://www.jaguarforums.com/forum/x...4/#post2404820
DTC Summaries Wiki with Updatable Field Findings (thanks to x350)
https://www.jaguarforums.com/forum/x...ipedia-246496/
DTC Chassis – 2003 (thanks to Don B)
https://www.mediafire.com/file/4776p...03_MY.pdf/file
DTC Powertrain EOBD – 2004
https://www.mediafire.com/file/gqih9...04_MY.pdf/file
DTC Powertrain OBDII – 2004
https://www.mediafire.com/file/8maux...04_MY.pdf/file
DTC Powertrain & Drive Cycles – 2004
https://www.mediafire.com/file/wgavp..._2004.pdf/file
Electrical Guide - 2003 MY
https://www.mediafire.com/file/p6ers...03_MY.pdf/file
Electrical Guide - 2004 MY
https://www.mediafire.com/file/kdhqj...04_MY.pdf/file
Electrical Guide - 2005 MY
https://www.mediafire.com/file/gagjz...05_MY.pdf/file
Electrical Guide - 2006 MY
https://www.mediafire.com/file/zk3vc...06_MY.pdf/file
Electrical Guide – 2008 MY
https://www.mediafire.com/file/i12hg...08_MY.pdf/file
Broken ground stud replacement
https://www.jaguarforums.com/forum/x...nt-how-126855/ (thanks to ragman1171)
Door Actuator Repair
https://www.jaguarforums.com/forum/x...repair-132821/ (thanks to henry crun)
Ground / Earth Studs Behind Headlamps - Maintenance and Service
https://www.jaguarforums.com/forum/x...6/#post1156791 (thanks to Don B)
Sidemarker Lamp Service & Replacement
https://www.jaguarforums.com/forum/x...2/#post1074810 (thanks to Don B)
Sunroof Repair X350
https://www.jaguarforums.com/forum/x...ir-how-129108/ (thanks to ragman1171)
Water in the Engine Control Module (ECM) (thanks to Blairware)
https://www.jaguarforums.com/forum/x...le-ecm-129598/
9. ENGINE
Oil Change – How To
https://www.jaguarforums.com/forum/x...nge-faq-67711/ (thanks to edobernig)
Spark Plug Change – How To
https://www.jaguarforums.com/forum/x...gs-how-104935/ (thanks to trosty)
Supercharger removal
https://www.jaguarforums.com/forum/x...r-i-pdf-84396/ (thanks to Jim Lombardi and Cambo)
10. FUEL SYSTEM
Fuel Pump – Repair & Replace
https://www.jaguarforums.com/forum/x...solved-153085/ (thanks to Lagonia)
Fuel Filter – Replace
https://www.jaguarforums.com/forum/x...ge-how-119351/ (thanks to Trosty)
Up to 2003, Jaguar called the vehicle guide a “Driver’s Handbook”. From 2004 it has been called the “Owner’s Handbook”.
Driver’s Handbook 2003
https://www.mediafire.com/file/xz9hw...21_40.pdf/file
Owner’s Handbook 2005
https://www.mediafire.com/file/9ipl8...1_502.pdf/file
Owner’s Handbook 2007
https://www.mediafire.com/file/bcv2v...1_801.pdf/file
Owner’s Handbook 2008
https://www.mediafire.com/file/oe8x2...1_802.pdf/file
12. INTERIOR
How to Remove the Back Seat:
https://www.jaguarforums.com/forum/x...t-back-151728/ (thanks to Cambo)
13. KEY FOB / REMOTE
Facts All You Need to Know - FAQ
https://www.jaguarforums.com/forum/x...now-faq-87749/(thanks to lcmjaguar)
Program Key Fob/Remote
Method #1
https://www.jaguarforums.com/forum/x...remotes-12736/ (thanks to XJ-Man)
Method #2
https://www.jaguarforums.com/forum/x...-2005-a-34092/ (thanks to Buck-MR2)
14. MAINTENANCE SHEETS
Vehicle Maintenance Sheet 2003
https://www.mediafire.com/file/wa3cs..._2003.pdf/file
Vehicle Maintenance Sheet (Diesel) 2004
https://www.mediafire.com/file/ycf2l..._2004.pdf/file
Vehicle Maintenance Sheet 2004
https://www.mediafire.com/file/wrp0x..._2004.pdf/file
https://www.jaguarforums.com/forum/g...6/#post1161325 (thanks to Don B)
Converted into a table in PDF (GGG)
https://www.mediafire.com/file/4g8cg...liers.pdf/file
16. PARTS
S N G Barratt - X350/X358 Catalogue download:
https://cdn.sngbarratt.com/catalogue...wnload2019.pdf
JEPC – Jaguar Electronic Parts Catalogue
Introduction:
Vehicle specification summary from JEPC
https://www.mediafire.com/file/u6col..._4441.pdf/file
Original download thread:
https://www.jaguarforums.com/forum/x...uctions-48194/ (thanks to Jim Lombardi)
Update for 64-bit Windows:
https://www.jaguarforums.com/forum/x...-fluid-149399/ (thanks to Jim Lombardi)
Issues following removal of Adobe Flash Player:
https://www.jaguarforums.com/forum/g...aphics-241868/
17. PHONE
Jaguar Connectivity Centre:
Looking for general help using your Apple or Android phone.
https://jaguar50.nextgen-technology....=23&RegionId=1
Smartphone Bluetooth Connectivity with Jaguar:
https://www.jaguarforums.com/forum/x...jaguar-152370/
18. TECHNICAL GUIDE
Technical Guide - 2004 MY
https://www.mediafire.com/file/g3o80...04_MY.pdf/file
Technical Guide - 2005 MY
https://www.mediafire.com/file/ehwqx...05_MY.pdf/file
Technical Guide - 2006 MY
https://www.mediafire.com/file/hzsuh...06_MY.pdf/file
19. TRANSMISSION
ZF 6HP29 transmission - Drain and Refill:
https://www.jaguarforums.com/forum/s...plained-37802/ (thanks to joycesjag)
ZF 6HP26 / 28 Transmission - Fluid Flush DIY:
https://www.jaguarforums.com/forum/x...9/#post2063302 (thanks to Don B)
ZF Transmission - Faults, Causes & Troubleshooting:
https://www.jaguarforums.com/forum/x...ooting-191572/ (thanks to meirion1)
ZF 6HP26 Transmission - Removal, Disassembly & Rebuild
https://www.jaguarforums.com/forum/x...ebuild-227587/ (thanks to jackra_1)
These 103 PDF’s in 17 sections have been collected from many threads (special thanks to motorcarman for advice on arranging them).
1 - Admin (3 Files)
1-186 Using WDS To Program Control Modules
https://www.mediafire.com/file/0li46...dules.pdf/file
1-224 Midtronics PSC-550 Vehicle Power Supply
https://www.mediafire.com/file/cypvv...upply.pdf/file
3-179 Scheduled Maintenance Program
https://www.mediafire.com/file/51qlz...ogram.pdf/file
100 – General (8 Files)
XJ100-01 Transportation of XJ Vehicles
https://www.mediafire.com/file/gakpd...icles.pdf/file
XJ100-02 Drive Belt Noise After Cold Start
https://www.mediafire.com/file/4q7jv...Start.pdf/file
XJ100-03 Buzzing/Knocking Noise
https://www.mediafire.com/file/lxk74...Noise.pdf/file
XJ100-08 Driveshaft Balancer Mounting Brackets
https://www.mediafire.com/file/jcv15...ckets.pdf/file
XJ100-09 Tail Lamp Adhesive Kit for XJ
https://www.mediafire.com/file/hs4zc...or_XJ.pdf/file
XJ100-10 Steering Rack Pinion Seal Replacer
https://www.mediafire.com/file/5250z...lacer.pdf/file
XJ100-11 Tyre Radial Force Variation
https://www.mediafire.com/file/zty8z...ation.pdf/file
XJ100-12 Transit Relay Removal
https://www.mediafire.com/file/ussxw...moval.pdf/file
204 - Suspension (9 Files)
XJ204-01 Diagnosing/Servicing Air Suspension
https://www.mediafire.com/file/fqzop...nsion.pdf/file
XJ204-02 Permanent ‘High Spot’ Marking
https://www.mediafire.com/file/85rz1...rking.pdf/file
XJ204-03 Shock Absorbers
https://www.mediafire.com/file/itnfz...rbers.pdf/file
XJ204-04 Corrosion Prevention – Wheels & Hubs
https://www.mediafire.com/file/mafvu..._Hubs.pdf/file
XJ204-05 Front Air Suspension
https://www.mediafire.com/file/xuobe...nsion.pdf/file
XJ204-06 Air Suspension System Diagnostics
https://www.mediafire.com/file/rg61i...stics.pdf/file
XJ204-07 Vibration Felt Through Steering Wheel
https://www.mediafire.com/file/8092f...Wheel.pdf/file
XJ204-08 Tyre Pressure Monitoring System
https://www.mediafire.com/file/tpxik...ystem.pdf/file
XJ204-S516 Spare Tyre Speed Restriction Label
https://www.mediafire.com/file/90829...Label.pdf/file
205 - Driveline (1 File)
XJ205-01 Driveshaft Vibration, Drone Noise
https://www.mediafire.com/file/3c2wr...Noise.pdf/file
206 - Brakes (8 Files)
XJ206-01 Vibration When Braking
https://www.mediafire.com/file/h8kce...aking.pdf/file
XJ206-02 Electronic Park Brake
https://www.mediafire.com/file/5d3wv...Brake.pdf/file
XJ206-03 Brake Caliper Flexible Hose
https://www.mediafire.com/file/glw5u..._Hose.pdf/file
XJ206-04 Creak Under Light Braking
https://www.mediafire.com/file/3jyfa...aking.pdf/file
XJ206-05 Brake Disc Replacement
https://www.mediafire.com/file/9l249...ement.pdf/file
XJ206-07 Electric Parking Brake
https://www.mediafire.com/file/7p7r4...Brake.pdf/file
XJ206-08 Vibration When Braking
https://www.mediafire.com/file/p2p24...aking.pdf/file
XJ206-09 Rear Brake Caliper Fluid Weep
https://www.mediafire.com/file/dfkdo..._Weep.pdf/file
211 - Steering (3 Files)
XJ211-01 Squeaking Noise
https://www.mediafire.com/file/y431m...Noise.pdf/file
XJ211-002 Power Steering Reservoir Replacement
https://www.mediafire.com/file/q3eyd...ement.pdf/file
XJ211-003 Steering Wheel Alignment
https://www.mediafire.com/file/uy1jc...nment.pdf/file
303 - Engine (13 Files)
XJ303-02 MIL On - DTC P0128 Stored
https://www.mediafire.com/file/nirqk...tored.pdf/file
XJ303-04 Engine Pinging, Detonation
https://www.mediafire.com/file/f6esq...ation.pdf/file
XJ303-05 Rough Idle, Hesitation
https://www.mediafire.com/file/gecdj...ation.pdf/file
XJ303-06 Cooling System
https://www.mediafire.com/file/67ax4...ystem.pdf/file
XJ303-07 Rough Idle After Cold Start
https://www.mediafire.com/file/4vz7s...Start.pdf/file
XJ303-08 Rough Idle/Restricted Performance
https://www.mediafire.com/file/hz4lg...mance.pdf/file
XJ303-09 Engine Pinging/Detonation
https://www.mediafire.com/file/pk5c4...ation.pdf/file
XJ303-13 Oxygen Sensor Calibration
https://www.mediafire.com/file/nq0w7...ation.pdf/file
XJ303-014 MIL On/DTC P050B Stored
https://www.mediafire.com/file/d19k6...tored.pdf/file
XJ303-S511 Oil Leak from Engine Oil Drain Plug
https://www.mediafire.com/file/hxp6o..._Plug.pdf/file
XJ303-S712 Coolant Hose
https://www.mediafire.com/file/nr5zb..._Hose.pdf/file
XJ303-S713 Coolant Reservoir Bleed Screw
https://www.mediafire.com/file/y88zv...Screw.pdf/file
XJ303-S717 Oil Cooler Pipe Interference
https://www.mediafire.com/file/i6pv6...rence.pdf/file
307 - Transmission (10 Files)
XJ307-00 Transmission DTCs P0780 to P0785
https://www.mediafire.com/file/mgrcu...P0785.pdf/file
XJ307-01 DTC P0741
https://www.mediafire.com/file/otu16...P0741.pdf/file
XJ307-01 Transmission Noise During Gear Shifts
https://www.mediafire.com/file/wp20q...hifts.pdf/file
XJ307-02 Knock When Downshifting
https://www.mediafire.com/file/j95j6...fting.pdf/file
XJ307-05 Squeak Noise During Acceleration
https://www.mediafire.com/file/plhjg...ation.pdf/file
XJ307-06 Harsh Transmission Shifts
https://www.mediafire.com/file/h059y...hifts.pdf/file
XJ307-07 Revised Labour Times
https://www.mediafire.com/file/ztfw0...Times.pdf/file
XJ307-08 Inability to Shift Gears
https://www.mediafire.com/file/kfl3j...Gears.pdf/file
XJ307-R513 Incorrect Gear Selection
https://www.mediafire.com/file/g2nne...ction.pdf/file
XJ307-R525 Incorrectly Manufactured
https://www.mediafire.com/file/9y5ed...tured.pdf/file
309 - Exhaust (1 File)
XJ309-001 Removal of Seized Oxygen Sensors
https://www.mediafire.com/file/culyg...nsors.pdf/file
310 - Fuel (4 Files)
XJ310-01 Erratic Fuel Gauge Reading
https://www.mediafire.com/file/zov4z...ading.pdf/file
XJ310-03 Fuel Level Sender
https://www.mediafire.com/file/asxfq...ender.pdf/file
XJ310-04 Fuel Filler Flap Will Not Open/Close
https://www.mediafire.com/file/7md6k...Close.pdf/file
XJ310-R726 Fuel Tank Replacement
https://www.mediafire.com/file/zjs74...ement.pdf/file
412 - AC (1 File)
XJ412-01 Air Conditioning (AC) System
https://www.mediafire.com/file/c6uhy...ystem.pdf/file
413 - Modules (4 Files)
XJ413-01 Additional Diagnostics for Instrument Cluster
https://www.mediafire.com/file/su7g4...uster.pdf/file
XJ413-01 Front Parking Aid
https://www.mediafire.com/file/f63rl...g_Aid.pdf/file
XJ413-02 Control Modules – PECUS Display Messages
https://www.mediafire.com/file/e3pod...sages.pdf/file
XJ413-02 Multiple Warnings on Instrument Cluster
https://www.mediafire.com/file/uqp6v...uster.pdf/file
414 - Battery (1 File)
XJ414-S724 Constant Battery Drain
https://www.mediafire.com/file/u52ka...Drain.pdf/file
415 - Audio (1 File)
XJ415-01 Incorrect Speaker Operation
https://www.mediafire.com/file/mk8tv...ation.pdf/file
417 - Lighting (2 Files)
XJ417-01 Headlamp Internal Condensation
https://www.mediafire.com/file/nqcey...ation.pdf/file
XJ417-02 Bezel Detached from Tail Lamp Assembly
https://www.mediafire.com/file/rbg2k...embly.pdf/file
419 - Phone & Nav (7 Files)
XJ419-00 Battery Discharged After Vehicle Has Been Standing for a Few Days
https://www.mediafire.com/file/rymz9..._Days.pdf/file
XJ419-01 Telematics Issues
https://www.mediafire.com/file/gmjxv...ssues.pdf/file
XJ419-02 Telephone Inoperative
https://www.mediafire.com/file/j8zh1...ative.pdf/file
XJ419-03 Navigation System
https://www.mediafire.com/file/blv7h...ystem.pdf/file
XJ419-04 Battery Discharged
https://www.mediafire.com/file/ai5sw...arged.pdf/file
XJ419-05 Complete Voice Range Not Transmitted
https://www.mediafire.com/file/y8rj8...itted.pdf/file
XJ419-S524 Navigation Control Module
https://www.mediafire.com/file/5i9hs...odule.pdf/file
501 - Body & Trim (27 Files)
XJ501-001 Windshield Damage Diagnostic Aid
https://www.mediafire.com/file/6von3...c_Aid.pdf/file
XJ501-01 Rear Entertainment Screen
https://www.mediafire.com/file/k1rxc...creen.pdf/file
XJ501-02 Luggage Compartment Lid Freezing
https://www.mediafire.com/file/xpoc7...ezing.pdf/file
XJ501-03 Vertical Seam Separation
https://www.mediafire.com/file/3a5jv...ation.pdf/file
XJ501-04 Intermittent Sticking of Switches
https://www.mediafire.com/file/xw2ps...tches.pdf/file
XJ501-05 Glove Compartment Lid Latching Issues
https://www.mediafire.com/file/j6w3o...ssues.pdf/file
XJ501-05 Loss of Seat Memory
https://www.mediafire.com/file/0ziie...emory.pdf/file
XJ501-07 Entry of Water into Vehicle
https://www.mediafire.com/file/hyius...hicle.pdf/file
XJ501-08 Floor Console Trim Separating
https://www.mediafire.com/file/5rbd0...ating.pdf/file
XJ501-09 Supplemental Restraint System
https://www.mediafire.com/file/ai9dk...ystem.pdf/file
XJ501-10 Glove Compartment Lid Difficult to Close
https://www.mediafire.com/file/6s4kb...Close.pdf/file
XJ501-11 Front Seat Backrest Rear Cover
https://www.mediafire.com/file/30rm0...Cover.pdf/file
XJ501-13 Water Ingress Around Roof Opening Panel
https://www.mediafire.com/file/gas8b...Panel.pdf/file
XJ501-14 Unoccupied Front Passenger Seat Noise
https://www.mediafire.com/file/fkx93...Noise.pdf/file
XJ501-16 Electrical Seat Judder
https://www.mediafire.com/file/vhjs4...udder.pdf/file
XJ501-17 Windshield Wiper Performance Issues
https://www.mediafire.com/file/6lk37...ssues.pdf/file
XJ501-18 A-Pillar or C-Pillar
https://www.mediafire.com/file/4xuu0...illar.pdf/file
XJ501-19 Exterior Door Handle Stiff
https://www.mediafire.com/file/1obk7...Stiff.pdf/file
XJ501-20 Key Transmitters Manual Programming
https://www.mediafire.com/file/rim57...mming.pdf/file
XJ501-21 Door Check Arm Noisy
https://www.mediafire.com/file/ddd20...Noisy.pdf/file
XJ501-22 Broken Centre Console Lid Handle
https://www.mediafire.com/file/6im81...andle.pdf/file
XJ501-023 Exterior Paint Issues
https://www.mediafire.com/file/flku8...ssues.pdf/file
XJ501-025 'Click' from Front Seat
https://www.mediafire.com/file/4r0gz..._Seat.pdf/file
XJ501-062 SRS Flash Code & PID Code
https://www.mediafire.com/file/802uf..._Code.pdf/file
XJ501-114 Rear Windshield Blind Motor
https://www.mediafire.com/file/gvhlo...Motor.pdf/file
XJ501-R719 Passenger Air Bag Door
https://www.mediafire.com/file/qrmqf..._Door.pdf/file
XJ501-S527 Key Fob Modification
https://www.mediafire.com/file/fbv19...ation.pdf/file
The following PDF is 55 MB. It is the six sections listed above merged into a single document.
https://www.mediafire.com/file/shgke...anual.pdf/file
This is the complete manual divided into 6 sections.
Table of Contents:
https://www.mediafire.com/file/mdmiq...tents.pdf/file
General Information:
https://www.mediafire.com/file/aap4o...ation.pdf/file
Chassis:
https://www.mediafire.com/file/n3yh7...assis.pdf/file
Powertrain:
https://www.mediafire.com/file/9b5wt...train.pdf/file
Electrical:
https://www.mediafire.com/file/0itho...rical.pdf/file
Body:
https://www.mediafire.com/file/4jou2...Paint.pdf/file
THE END
INDEX
1. ACCESSORIES
3. AIRCON & HEATING
4. AIR SUSPENSION
5. BRAKES
9. ENGINE
10. FUEL SYSTEM
12. INTERIOR
13. KEY FOB/REMOTE
17. PHONE
18. TECHNICAL GUIDE
19. TRANSMISSION
1. ACCESSORIES
3. AIRCON & HEATING
4. AIR SUSPENSION
5. BRAKES
Sunroof Repair X350
9. ENGINE
Oil Change – How To
10. FUEL SYSTEM
12. INTERIOR
Method #1
Method #2
16. PARTS
Introduction:
17. PHONE
18. TECHNICAL GUIDE
19. TRANSMISSION
1 - Admin (3 Files)
XJ307-01 DTC P0741
412 - AC (1 File)
Table of Contents:
Chassis:
Powertrain:
Electrical:
Body:
THE END
Last edited by Don B; 04-23-2024 at 10:33 PM. Reason: Updated to add SNG Barratt catalogue link
The following 16 users liked this post by GGG:
AD2014 (05-23-2021),
Cneukum (05-24-2021),
cybercontroller (01-04-2022),
Don B (05-22-2021),
Frankyodee (10-11-2022),
and 11 others liked this post.
