Xenon light out!
The left side xenon light on my 2005 XJ8 is out. I swapped bulbs and it is not the bulb as neither bulb works in the left position. I also checked the fuse box and eache light is on a seperate fuse - no problem there either. It takes the D1s bulb - can I assume that the ballast is out - or is there possible a less expense cause?
Received 2,191 Likes
Given,
If I understand correctly, another bulb works, but the original bulb does not work. If that is the case, it sounds like you have a bad HID, not the ballast.
If so, I found a good aftermarket supplier of D1S bulbs on Ebay. At least for the price ($60/pair) they're far less expensive than OEM D1Ss. I have them in my X350 for a couple of month now and I am happy with their performance. I tried the 8000K which are a little ice blue, but nice and bright. The Ebay company is Formula-J87 (no affiliation).
Try searching for them on Ebay and hopefully you can purchase them in Italy if you discover, in fact, that the bulb is expired.
rsa760041
23
09-25-2015 01:33 PM
