xj 2.7 non start
xj 2.7 non start
hello all ,back to repairing my 2008 xj 2.7 .it has not started for 3 years .all wire connects checked, fuses checked ,earth wires checked and repaired .can turn engine on fuse with a link .found a ecu same spec and had it cloned.its on second new battery. faults on dash gear box/hand brake/abs/dcs/cruise control cannot talk to it with scanner . cannot clear codes same fault as from day one ,any help would most appreciate.
1 gearbox fault/ 2 dsc fault /3 air suspension fault / 4 abs fault/ 5 park brake foot brake fault / 6 cannot apply h/brake / 7 limiter / 8 cruise
hi need to know were ecu earths have been told this could be the problem any ideas?
JagMan2020
03-28-2020 03:36 PM
Jaguarsmg1
01-27-2017 04:10 PM
talashek
08-09-2012 01:32 PM
