XJ Air suspension ride height adjustment
Jag XJ8 LWB 2005.
I notice around 2010-12 there was quite a lot of talk about developing a manual ride height adjustment module/kit - I think WhiteXKR was leading the way on this as an alternative to the Arden product which is/was very expensive.
Did this ever materialise? and if so is it currently marketed?
Hello Viper1996.
Yes, I want to be able to manually lower the car when passengers are boarding ( I use the car for chauffeur work) then resume ride height once they are in the car before driving away.
Could an electrically operated bleed valve be installed on the valve block with a link to inhibit the operation of the compressor until the bleed valve was closed?
I thought Range Rover offered this facility on the Vogue which might be a way seeing that the two cars share similar suspension set ups......
Any ideas out there?
gears
06-01-2024 07:12 PM
