XJ wiper replacement
Old 06-11-2017, 09:40 AM
Otakar's Avatar
Gentlemen; I just joined this site, just for the reason of thanking you for all the help. My 2004 XJR has the wide insert blades and according to my dealer the only thing to be done is to replace the "wiper system" Yea Right. I just ordered the Bosch kit on eBay from the UK. $29 shipped to the US. As some of you have also attempted, to find them on this continent, I have also not been able to.
Thank You So much for the help
Otto K.
  #42
Old 06-11-2017, 10:02 AM
Otakar's Avatar
Originally Posted by Partick the Cat
There must be a US importer surely ? At least two major auto-accessory chains here in the UK stock them.
There is no US dealer for these. I have now been searching for three weeks on the WWW. I ordered them from the UK because the price was not any different than buying a regular set of blades at the local parts store. They actually wound up being less expensive even with shipping. This is what I bought. BOSCH 3397007654 / AR608S Set of AEROTWIN RETROFIT Windscreen Flat Wiper Blades
philwarner (06-14-2017)
  #43
Old 06-11-2017, 10:05 AM
Otakar's Avatar
The only countries I have been able to find these are Germany, UK, and Latvia.
  #44
Old 06-11-2017, 10:20 AM
Otakar's Avatar
By the way, a set of inserts for these is very inexpensive. less than $10 2 x Wischergummis für BOSCH 3397007654 AR608S AEROTWIN Scheibenwischer 600/475 | eBay
It might be worth it to buy a spare set or two for the future. In this way they can be replaced every year or two the way they should be.
  #45
Old 07-22-2017, 03:03 PM
Thanks. I did the same thing. After not being able to find replacement cartridges with the spray nozzle, and seeing the cost of buying the replacement nozzle at about $20, I decided that all I really needed to do was remove the worn out blades and metal carriage and replace those. Purchased the same size blades and removed them from the carriage that they were in. Squeezing with a pliers on the end which has a small catch to lock them into the carriage gets them to slide right out. Did this on both the old carriage and the replacements. Then merely have to slide the new blade and metal carrier into the old carriage and put back onto the wiper arm. Hooked up the washer hose and voila, new wipers! Cheap and easy.
  #46
Old 07-22-2017, 04:02 PM
Otakar's Avatar
That's what I wanted to do also, but I couldn't. My OE wipers had the 12mm blades and even the inserts I got from Jaguar would not fit because they only have the 8mm ones. For the Thirty bucks including shipping it was worth the purchase from the UK. It was less than a five minute job to change them and they actually look better than the OE wipers.
Forcedair1
05-14-2023 03:28 PM
KarimPA
09-12-2015 08:15 AM
mcdutch
09-04-2015 03:38 AM
KarimPA
09-03-2015 07:32 PM
XJsc-guy
09-02-2015 11:43 AM
Quick Reply: XJ wiper replacement
