xj6 v6 3litre
xj6 v6 3litre
I have a 2003 xj6 3 litre, when driving from cold at mid revs I can see the revs counter fluctuating a couple hundred revs and I can feel the car holding back as if it's mis-firing but no noise.
As it warms up the issue lessons and eventually goes all together. it does this every day, no fault codes showing.
can anyone help?
thanks
can anyone help?
thanks
You have the notorious 'hunting' syndrome. My car has had it from when I bought it in 2010, and still has it despite attempts to cure it. As you say it eventually disappears, and this when the transmission fluid has warmed up. I just put the transmission into '3' for a bit. As far as I can tell no harm is caused, and as my car had it at 30k miles on purchase and still has it now I'm on 114k miles that seems right. Later cars had a different torque converter clutch which apparently gets rid of it; expensive fix though. I was told the TCM engages/disengages the lock-up clutch to warm up the transmission fluid, so it is a software issue. Later torque converters have reprofiled friction surfaces.
If only one could get hold of the TCM source code to fix it !!
