XJ8, 4.2, 2005 Alternator Replacement
Hello Jag Enthusiasts,
Need some advice on replacing an alternator on a 2005 XJ8. The JTIS states to raise the engine and remove the steering gear. I have read posts where some have removed through the wheel well. Any pointers would be greatly appreciated.
Thanks,
Ray
Thanks,
Ray
I was very recently looking at diodes and found this:
Alternator Repair,bad alternator,diagnose symptoms repair problem
They look like alternator repair specialists.
I saved huge amounts of $$$ buying my Bosch Alt from parts geek. It has a better warranty than the dealer. Was the EXACT match. Yes it was a rebuilt, but by Bosch. Most people dont know that even alternators purchased from dealers are rebuilt. The only way to get a NEW Alt is with the new car. This is true for most MFR's.
I did have the dealer install it after I pre tested it. Labor $$ wasn't too bad, considering the hassle to get it out and in. Yes the front end has to be dropped, and motor supported from the top. And there is 1 bolt that is a real B*^ch to get back in. Made a rig for my XJ-40 to support the motor from the top that probably would have worked. It was worth it to pay them to R/R. Got a loaner, and was done that day.
