I've seen a few threads on lowering your X350, and wanted to post my setup.
Wheels:
Avant Garde M220
Front: 18x8 +30
Rear: 18x9 +30
(I also have 30mm spacers to make it flush to the fender, but I haven't rolled my fenders yet so I'm just going to leave it as is until next year)
Tires:
Front: 215 45 18
Rear: 225 45 18
Suspension:
BC racing coil overs. They had to be custom made, but I didn't spec custom springs or an extreme low kit.
(ride is surprisingly smooth and coilovers are fully adjustable so I could soften it more as needed. Rides a bit stiffer than stock given the 45 sidewall
Dash lights:
-Yellow warning light
-Messages: "Issue with Air suspension" and "CATS system fault" (or similar - I forget the exact wording)
-Not getting the Red vehicle too low message/light.
Taking it in a few weeks to get the codes cleared by a local Jaguar shop (hoping that's easy vs having to buy some sort of module faker)
I am surprised that you put tyres that "thin", meaning with an insufficient load index.
The standard load index of a 215/45 R18 is only 89, and it is 93 when XL.
Even a 225/45 R18 is 91 and 95 XL respectively.
For reference, the standard tyre on an X350 is 235/50 R18 with a standard load index of 97 (and 101 if XL)
It should fit no problem, but I'd reach out to BC racing to confirm. They were pretty helpful when I was ordering so it'd definitely be worth the message to them before spending the money.
