XJ8 cranks but no start (P0627)
Must be something with the fuel pump/system. Did you try disconnecting your battery? to see if the fault goes away?
Or maybe that's not a good idea. How about your fuel level does it show as having fuel? In my case the REM was disconnect thats why it didn't start but cranked.
Sometimes things just glitch. So if it shows that u have gas try disconnecting the REM and them reconnecting it?
Once again, some on should chime in, i'm a noob, but that's what I would try.
Generic OBD Error Code Details for P0627
Fuel Pump "A" Control Circuit /Open
OBD Code P0627refers to
ECM detected an open or short in the fuel pump relay circuit
Symptoms
Possible sumptoms of OBD code P0627
- Engine Light ON (or Service Engine Soon Warning Light)
Causes
Possible causes of OBD code P0627
- Fuel pump circuit open or short - Fuel pump circuit poor electrical connection - Faulty fuel pump relay - Faulty fuel pump control module (if applicable)
When you have a code look up on OBD.com
Symptoms
Causes
Hmm, don't know if a wiring diagram would help you or not. Wondering where u can get one of those anyway...
good luck, I'll let u know if I think of something... unlikely... but it may come in a dream lolol..
Edit, if it is ur REM maybe u can send it out for repair. I know a company here in toronto that does things like that. It's called speedofix. Perhaps you can locate something similar in ur area. (cheaper than buying a new one?)
RoyLittle0
05-25-2023 02:38 AM
