XJ8 Front Bumper Cover Removal
I need to remove the Power Steering Cooler due to a leak.
Service manual says to remove the bumper cover to gain access. I can't seem to get the seam at the fender to pull loose on either side. The illustration shows what appear to be five spring clips holding the cover to the bottom seam of the fender. They must be very tight.
I thought that I would go to "Plan B" and remove the headlights and then the support bar that the lights attach to and then gain access to the cooler from the top. I can see the cooler from the top, I just can't get to it.
Service manual again calls for removal of the bumper cover in order to gain access to the two bottom bolts of each double headlamp assembly.
Has anyone removed the front bumper cover? If so, how did you get the seam at the front of the fenders to come loose? I don't want to bend the fenders trying to pull the cover loose.
mikebaker3 (01-06-2017)
Received 12,952 Likes
Hi Mike,
The bumper cover has three sort of D-shaped tabs along its top edge that slip into the seam, and the opening in each D tab clips over a raised projection or tapered stud along the lower edge of the seam. You can just pull the fender cover out, but some or all of the D tabs may break. I learned this the hard way. Here's a method that may not be Jaguars approved procedure, but it works for me without breaking the D-tabs:
Apply two layers of masking tape along the upper and lower edges of the seam to protect the paint.
Using two narrow flat-bladed screwdrivers, insert one screwdriver inside the D-clip but on each side of the raised stud, so both ends of the D-clip have a screwdriver under them. While pushing in slightly on the bumper cover, carefully pry up on the D-clip with both screwdrivers until it clears the stud. Place a plastic trim prying tool or some other object between the bumper cover and body to prevent the cover from snapping back into place.
Repeat for each of the D-clips until the bumper cover is free.
If you haven't yet removed the grille, it's easy. Just remove the two Torx screws on the top corners of the grille, carefully pry apart the plastic where it snaps over a round tapered stud, and the entire grille will pull forward and out.
Cheers,
Don
Cheers,
Don
The following 2 users liked this post by Don B:
AD2014 (01-12-2017),
mikebaker3 (01-07-2017)
AD2014 (01-12-2017)
I needed to take my bumper cover off this weekend. I've done it before, but managed to break one of the D clips on each side in the process. That time I was trying to pry the gap apart whilst pulling the bumper outwards.
Quite by chance, this time I pulled the bumper forwards. To my surprise it moved quite easily and another gentle pull had it free of the car. The other side came out just as easily. Having removed the bumper, I took a closer look at the studs which it clips to:
Here's a view with the three retaining tabs circled.
Here's a close up of one of the tabs. You can see the rear edge has a gentle slope making it much easier for the D tab to ride over it if pulled forwards.
This is looking along the length of the car at the front tab. You can see a gentle slope towards the outer edge making it easy to clip the bumper in. The rear edge is quite steep (to hold the bumper in place), and this is what you're trying to get the D clip to ride over if pulling the bumper outwards.
So, it seems to me the manual is quite misleading. The studs appear to be designed to make it easier to remove the bumper if pulled forwards rather than outwards.
Julian.
Julian.
The following 7 users liked this post by jbarringer:
Aix (05-12-2023),
Don B (11-04-2018),
Leslie Graham (Levitikon) (11-06-2018),
patricktgreen (07-27-2020),
Samilcar (04-17-2021),
and 2 others liked this post.
I have not had any problems removing the bumper cover, at least on my car it comes off very easily, much easier than the one on my Audi A4 from 1998.
You cannot just pull it towards the front,you also need to pull it outwards at the same time because otherwise it will not clear the plastic holding it in place.
Best regards,
Thomas
Best regards,
Thomas
