XJ8 Rear Suspension Sagging - VTL & ASF - No OBD Codes
1 Post
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
My 2004 XJ8's rear suspension is sagging badly on both sides but the front suspension seems fine. The ride is very rough, the bottom of the car is scratching mild speed bumps.
Error codes:
- Vehicle Too Low (red light)
- Air Suspension Fault (orange light) (40-45s after engine start)
- no OBD errors (yet)
Thank you for your help. I appreciate it.
PS: I’ve seen the ASF code before but rarely maybe once every few months.
Error codes:
Last edited by d0lph1n; 05-28-2019 at 07:10 AM. Reason: I forgot to mention the suspension is sagging on both sides (rear)
1 Post
I tried to listen to it yesterday and I can't tell if it's on or off.So far, I started the car 3-4 times for 2min each time and everytime, after 45s, just the ASF warning pops up on top of the VTL warning. The rear suspension's height remains very low, the rear fender covers the top of wheel and the front suspension remains at the same height 1-2 inches above wheel.
1 Post
The compressor doesn't work. The3 fuses related to the air suspension are OK - 1x engine-compartment | 2 x in-the-trunk.
What's next? Please advise.
P.S.: I already have the air compressor rebuild kit.
This might be worth trying:
Key off
Break joints to release air pressure until complete system
is depressurised.
Remake joints.
Disconnect both battery leads and touch together
Replace battery leads.
Run engine.
If the suspension partly lifts listen for leaks.
If the suspension does not lift if possible drive vehicle for up to 20 mins.
No guarantees but it has worked in the past.
Key off
is depressurised.
Remake joints.
Run engine.
Don B (06-07-2019)
1 Post
Thanks, for your advice.
I’ve bench-tested the compressor and it’s working. Before I put it back I’ve rebuilt it using the ebay kit.
After I installed it back on the car, it started right away but it stopped after 1-2 min. Waited 1-2 min, restarted the car, the compressor started again.
So I’ve followed your advice:
- released the air pressure from the entire system...by disconnecting the air spring ports from the valve block. The front suspension completely dropped
- Disconnected the battery, touched the leads
- reconnected everything back, double checked the fuses, restarted the car multiple times and nothing happenes
- the compressor doesn’t start, the car looks like a low rider on all corners
I can’t drive over speed bumps so I can’t drive for 20min
Please advise
Please advise
Don B (06-07-2019)
1 Post
I couldn’t find a solution to drive my low ride over the speed bumps yet. There are at least 5-6 speeds bumps on the path to the main road. I still don’t understand why the compressor doesn’t start anymore, so today I took it out and I’d like to check its carbon brushes.
do you know what’s the purpose of the compressor’s valve (next to the dehumidifier) and who’s controlling it?
1 Post
An exact model compatible with 2004 Xj? Most of the cheaper ones are compatible with newer models 2005 and up
Received 12,952 Likes
If your car has entered Jacking Mode, you may just need to get it up to 2 mph to reactivate the suspension.
If your compressor ran for 1-2 minutes, don't worry about the brushes. The ASM limits the compressor to 2 minutes of run time to prevent overheating and will impose a cool-down period of at least 45 seconds.
The valve on the compressor is the exhaust valve, which is the only designed route for air to be released from the system. It opens when one or more corners of the car need to be lowered, and it also opens periodically to allow dry system air to backflow through the air drier to partially reactivate the desiccant beads.
This post describes all the system components and operation:
Air Suspension & ECATS System Summary: Components & Operation
If you can find a local shop with a diagnostic scan tool capable of reading the proprietary Jaguar Body (B-prefix), Chassis (C-prefix) and Network (U-prefix) codes, they may help narrow down your diagnosis.
Cheers,
Don
1 Post
Hi d0lph1n,
Cheers,
Don
Cheers,
Don
Cheers,
Don
I had a similar "rear end sag" problem with mine. Turned out to be a bad level sensor and a bad ASM. Repaired fairly cheaply with used parts, never had a problem since. It took a specialist with the proper diagnostic kit to find the problem though.
The exhaust valve on the compressor can get blocked up with gunk sometimes, easy to clean out - just held in place with 2 screws as I remember. This is best done with the compressor on a bench, very hard to get the springs back in place from underneath the car!
Don B (06-09-2019)
Mine looked exactly as you described yours; wheels under the arches by quite a bit.
Don B (06-09-2019)
