XJ8 Rear Suspension Sagging - VTL & ASF - No OBD Codes
Don B (06-12-2019)
1 Post
Yes I did, around 50ft (until the 1st speed bump) for a few times, and to my surprise, the compressor started every time the car started, for around 45s. So I figured out, I’ll start/stop the car for 1-2 min with a 2min break, to recharge the system. It worked fine, 10 times. After that, the compressor started randomly or not at all but the suspension is still sagging on all 4 wheels. Sometimes the ASF appears sometimes it doesn’t and the error related to handbreak that appeared after I’ve empty the air system, disappeared.
Don B (06-14-2019)
Recently I had a fault on my Jag and called a mobile mechanic to diagnose.
The fault was a misfire and I changed a coil which solved the problem.
It cost $88 for an hour of his time.
I suggest that you find a local man to diagnose the fault.
I now have an icar soft which I keep in the glove box.
WayneHWilson
07-24-2018 04:10 AM
