XJ8 Vent Problem
The driver and passenger side systems are separate from an air-flow point of view but have a common heater core that spans both sides of the system. As Fraser said, one side of the core often gets silted up so if back flushing doesn't fix it a new core will be required.
I had the core on my '04 changed a year or two ago because of this issue.
I have a 2005 XJ8 and mine has the same symptoms. The dealer says the problem is the blending door (mechanical). The servo motor is not working, and the only way to fix is an entire new heater box $3,000 installed. There has got to be a less expensive alternative?
Anyone have any suggestions?
No luck so far. Don't know where the vent door is, don't know what it looks like, don't know if its mechanical or a controller. No luck finding any pics or instructions. If its mechanical can it be wired open? Someone also said it may be the DCCV. Same problems as the vent door. Let me know if you have any luck (aacbsfb@gmail.com)
Maybe its this site. Same issues with wanting to recover the B Pillar!
""No luck so far. Don't know where the vent door is, don't know what it looks like, don't know if its mechanical or a controller. No luck finding any pics or instructions. If its mechanical can it be wired open? Someone also said it may be the DCCV. Same problems as the vent door. Let me know if you have any luck (aacbsfb@gmail.com)
Maybe its this site. Same issues with wanting to recover the B Pillar! ""
Hey you guys!
Sorry you are not making progress.
If you both want to email me @ robatmeirion@gmail.com I will send you attachments:
Technical guide
Electrical guide
Some info here https://www.jaguarforums.com/forum/showthread.php?p=284793#post284793
Bob
Hey you guys!
Technical guide
Electrical guide
Bob
