XJ8 Vibration
2004 XJ8 64K miles. Brand new Mich 235/50/18"tires. Car has drive train vibration, seats and body vibrate under acceleration and at cruise speed seems like a rumble, but not all the time. Can feel vibration in the steering wheel at 50 mph, almost like the power steering pump is out of balance. Tires were re checked for balance and they are perfect. Getting more frequent, car is smooth at lower speeds. Seems like a bad U joint?
Get the vehicle in the air with a driver inside and bring to 20, 30, 40, 50 mph to determine the worse harmonics. I know the X-type has AWD/option for it, but unsure of the XJ8. Either case, it appears you have a bad joint, or a bad mount causing the drivetrain to come out of alignment.
Hope this helps!
Ryan
william184 (06-19-2011)
