xj8 wont start
Old 01-12-2015 | 08:42 AM
b787's Avatar
Your problem sounds very similar to mine, you said you can get the starter to crank. Have you tried to turn the key to II position and cranking the starter again (jumping) and will the car start?
Old 01-12-2015 | 10:21 AM
sreed08's Avatar
3000.00 sale pending
Old 01-12-2015 | 10:01 PM
Rickkk's Avatar
Don't press the panic button. Have it towed to your local Jag dealer, and have them take a look at it. It's not an intermittent problem at least so they should be able to find what's wrong.
Old 01-13-2015 | 09:35 AM
panels's Avatar
Originally Posted by Rickkk
From the symptoms that you described, it acts like there's a poor earth ground somewhere. Try checking for continuity between the negative post of the battery (leave the negative battery terminal connected), and an earth ground in the bonnet area. It's best to disconnect the positive terminal from the battery before performing this check.
I had the same issue of no start and for some reason I disconnected the positive cable at the starter and cleaner it. That did it in my case.... Another easy thing to try along the way.
Old 01-13-2015 | 02:59 PM
Rickkk's Avatar
He's also claiming that the windows will not go up, and the radio will not work (among other things). Fortunately, it's not an intermittent electrical problem so it shouldn't take long at all for a Jag dealer to repair it.
Old 01-13-2015 | 09:18 PM
RDMinor's Avatar
Default Starter works but car won't start?
Originally Posted by sreed08
OK car does not crank. I jumped the starter out and it works. I checked all fuses. Under hood cabin and trunk. None of the lights on the dash come on. I already did the reset and nothing. Well the radio started working after . but the windows and dash still doesn't work. The security light doesn't flash either. And like I said the windows are down and can't get them to go up. I did get the sunroof to close by turning the key to lock position.
I missed something in your tale of woe. You state that you jumped the starter and it works but you didn't say if the car would also start that way.
Very odd for it not to crank .....AND..... also not start if you jump the starter and the starter works. You've checked the solenoid ?? You checked the continuity of the feed wire to the solenoid? You've checked the continuity of the solenoid to starter connection?
Very odd for some of the electrics to work while others refuse to even with a new battery. You've checked all of the grounds??
I have a nasty feeling that someone is going to steal a car and get it fixed on the cheap for something that's been overlooked.
Good luck.
Wolfy
05-28-2024 09:06 AM
JarodL
03-07-2024 02:39 AM
dsnyder586
04-04-2019 03:38 PM
Bones
09-08-2015 09:34 PM
Jaguar Forums Editor
Jaguar Press release
09-03-2015 10:38 AM
Quick Reply: xj8 wont start
